Old 11-09-2006, 05:37 PM   #1 (permalink)
Default limewire loads every minute.help!
hey could someone help me please,i tried using limewire,and now it loads automatically on start-up and so i tried un-installin it and i get the message 'limewire launch error' can someone help me?
koolkapoor is offline
Old 11-09-2006, 08:11 PM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default Re: limewire loads every minute.help!
u can remove frm startup usin msconfig...or there is an option in limewire as well
and if ya still wanna uninstall it...jus exit limewire frm the tray and delete the folder
vijay_7287 is offline
Old 11-09-2006, 08:53 PM   #3 (permalink)
deepgeek2's Avatar
@koolkapoor .Follow Vijay's method. He is 100% right.
Pllleeeeeeeeaaaazzzzzzzzzzzzzzzzzzzeeeeeeeeeee add to my Repu points if you think i was helpful.
deepgeek2 is offline
Old 11-09-2006, 09:54 PM   #4 (permalink)
Pragadheesh's Avatar
Post Re: limewire loads every minute.help!
follow wat vijay said. to be more specific, In RUN , type msconfig & in d dialog box which appears click Start up tab & uncheck Limewire & its related stuffs.. the least applications u keep in Start up the faster 'll be ur system.
Pragadheesh is offline
- by Krow
