| Forum |
#2 (permalink) |
u can not open jpg files using MS Paint.u have to use softwares such as ACDSee or IrfanView.IrfanView is a free software and supports a LOT of formats.install it and while installing,associate JPEG,JPG files withe IrfanView and then u can open the files.also u can convert BMP(Paint) file to JPG,just use Save As option in IrfanView.
It is available in Digit CDs or download here:- http://www.irfanview.com/
http://swatrant.blogspot.com/ |
#3 (permalink) |
MS paint in windows XP opens and saves jpgs as well as gifs
which OS are u using ? did u have the option before ? and has it just disappeared ? or are u just noticing it ?
No Mercy, No Limits. Oobertech.net - Keeping Knowledge Free |
#4 (permalink) |
i have windows 2000 prof.
also in all windows (98.xp,2000) ,ms paint supports jpg images. yes previously i had the option, but now has dissapared . we do not require seperate viewer for the same unless and untill u want easy and quick access. so plz help me out , so that i can view jpg images in ms-paint. |
#5 (permalink) |
try uninstallin and reinstallin paint !
goto control panel=> add/remove programs=>add/remove windows components=>accesories and utilities=>accessories deselect paint there click ok 3ce ... and continue .. follow it through give ur pc a restart just in case then follow the same steps and recheck PAINT .. now for ol times sake give it another restart and check
| Bookmarks |
| Display Modes | |
