Old 10-09-2006, 04:23 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default change the 'registered to'
guys all my office machines which my engg gave me have the windows and office registered to '.' i wanna change this to the company's name .... i know this can b done thru regedt but dont know which entry to edit .... some1 please elaborate
http://beingmanan.com
iMav is offline
Old 10-09-2006, 04:28 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: change the 'registered to'
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion
In right-side pane, change RegisteredOwner & RegisteredOrganization to the desired one.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 10-09-2006, 04:30 PM   #3 (permalink)
Google Bot
Pathik's Avatar
hkey local machine/software/microsoft/windows nt/currentversion/registered owner...
__________
oh sorry vishal i didnt see ur post..... neways no1 can beat u in this...
Pathik is offline
Old 10-09-2006, 04:32 PM   #4 (permalink)
Microsoft MVP
lol, seems that we posted at the same time approx.
Old 10-09-2006, 04:34 PM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
But can we change that "Registered To:" to something diff? Like, Owned by or etc... ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 10-09-2006, 04:45 PM   #6 (permalink)
Microsoft MVP
YES! Hack sysdm.cpl in Resource Hacker.
Old 10-09-2006, 07:09 PM   #7 (permalink)
Distinguished Member
anandk's Avatar
...or u can also use tune-up utilties(system control), aso-windows optimizer, etc to easily change ur registration information...
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 10-09-2006, 09:16 PM   #8 (permalink)
Commander in Chief
Ok, will do that VG, thanks.
Harsh J
www.harshj.com
Old 10-09-2006, 09:34 PM   #9 (permalink)
iMav's Avatar
thanks for that guys ..... and if i wanna change the MS Office registration ???
iMav is offline
Old 10-09-2006, 09:55 PM   #10 (permalink)
deepgeek2's Avatar
CAn we chane "registered to" for all other softwares?
Pllleeeeeeeeaaaazzzzzzzzzzzzzzzzzzzeeeeeeeeeee add to my Repu points if you think i was helpful.
deepgeek2 is offline
Old 10-09-2006, 09:56 PM   #11 (permalink)
Google Bot
Pathik's Avatar
hkey current user/software/microsoft/office/10.0/common/user info/user name.....
modify the binary data n replace the letters wit ur name.... u may need to kno hex
Pathik is offline
Old 10-09-2006, 09:57 PM   #12 (permalink)
Microsoft MVP
And also u can edit this:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr ent Version\Installer\UserData\S-1-5-18\Products
Under this key, u'll find several keys (based on what u hv installed on ur comp) with the name like, 9040110900063D11C8EF10054038389C, etc.
Under those keys, u'll get InstallProperties key. In right-side pane, change RegOwner & RegCompany to ur desired one.
Old 10-09-2006, 11:18 PM   #13 (permalink)
iMav's Avatar
to the base 16 wala hex ????
iMav is offline
Old 10-09-2006, 11:33 PM   #14 (permalink)
Microsoft MVP
a-i => 61-69
j-o => 6A-6F
p-y => 70-79
z => 7A
A-I => 41-49
J-O => 4A-4F
P-Y => 50-59
Z => 5A
Old 11-09-2006, 11:12 AM   #15 (permalink)
k_blues24's Avatar
Tune-up utilities also works for u
I try it, & it works
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
- by Krow
