dual layered discs can be READ by any dvd rom drive
what ur dvd writer means is that it cannot WRITE dual layered DVD's !!
DUAL LAYERED DVD's or DVD9's as they are called have double the capacity ( i like to call it data density
) as DVDs' or single layered DVD discs .. or the normal Discs u get ....
also there is something called as DVD10's or DUAL SIDED DVD's
which is basically 2 DVD5's ... one on each side
yup ... u have to flip the DVD to read the rest of the content
DUAL LAYERED simply means ( in comparison ) that one side ( the read / write side ) has 2 layers ... as opposed to flippin the DVD for reading the rest of the INFO ! and as opposed to DVD5's which offer only 4.3 gb of space
DVD5's and DVD10's offer double the space .. ofcourse as per their name
bothe the layers/sides ( depends ont he DISC) are read by the same wavelength laser ... however writing on the second "LAYER" ( note: NOT SIDE ) is a lil difference ..
HENCE not supported by all DVD "WRITERS"
u need a special DVD WRITER ... viz a DUAL LAYERED DVD WRITER !
DL writers are currently in the DVD+R stage .. as opposed to DVD-R which is mire widely used ...
for more on DVD FORMATS search the forum for an article by sara2002 !
