Old 09-09-2006, 09:15 PM   #1 (permalink)
Pragadheesh's Avatar
Unhappy folder cant be found in the hard disk!!!
i was adding files to make a dvd using Nero(7) Burning ROM.
Accidently i found a folder named "SYSTEM VOLUME INFORMATION" in the Nero burning ROM. when i clicked it ot view its contents , it displayed "F:\System volume information is not accessible. Access Denied".
i'm the administrator.
Also there is another folder "RECYCLER" which contains
S-1-5-21-1085031214-...........................
S-1-5-21-1202660629-57989841-682003330-1003
S-1-5-21-1202660629-57989841-682003330-1004
S-1-5-21-1202660629-57989841-682003330-1005
S-1-5-21-515967899-..............................
These 2 folders are seen in every drive using Nero burning rom
but none of these 2 folders is seen in any drive(Show hidden files is enabled).
Its only seen in Nero burning rom.
Any idea of why this is happening??
Pragadheesh is offline
Old 09-09-2006, 10:07 PM   #2 (permalink)
Anand_RF's Avatar
Default Re: folder cant be found in the hard disk!!!
You can't see them even if you are admin.
Recycler, you can delete the files in there without it affecting winxp.
As for sys vol info, you can never see what's inside if you're on NTFS.
btw, you can see every folder in your pc including recycler and sys vol info if you check "show protected operating system files and folders" and "show hidden files" from folder options in explorer.
Anand_RF is offline
Old 09-09-2006, 10:23 PM   #3 (permalink)
-- No Easter Eggs here --
hemant_mathur's Avatar
They are system files .. just let them be there they wont harm the system in fact they are good for the system.
E6850 3.0 Ghz, 4gb 667 Mhz RAM, Asus p5n Esli Mobo, Nvidia 8600GT 512mb, 400gb WD HDD, Samsung Syncmaster 920NW, Vista x64
hemant_mathur is offline
Old 11-09-2006, 06:57 PM   #4 (permalink)
Post Re: folder cant be found in the hard disk!!!
thnx anand. as u said by enabling Show protected OS files i can see those files. also my drives r NTFS formatted.
Also wat does these folders actually do? and why in NTFS alone it cant be seen?
Old 11-09-2006, 07:39 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can see their contents!
Just right-click on the folder and select Properties. And in Security tab, click on Add button. and in the new windows add Administrators. Now Apply it. After this u can open the folder, see the contents, even delete the whole folder. Don't worry, it'll be create again-n-again
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 11-09-2006, 08:10 PM   #6 (permalink)
SE><IE
Posts: n/a
don't worry, this is the way recycle bin arranges the files (perhaps)
open it as vishal said (i.e. giving yourself permission) and you'll find some folders as _restore{6776F958-B3F1-4A1F-B3B9-6DA89AC9ADCB} (similar). These are restore points and I hope you know why they are made inaccesible by default (suppose you delete these folders and then use system restore)
- by Krow
