Old 09-09-2006, 05:06 PM   #1 (permalink)
Question VCD on DVD
Hi Friends,
I want to write normal video (.dat) files on a DVD disk. i am using nero premium 7.2 version. But the problem is that when i try select the media type as DVD disk and add video to the compilation, it starts the conversion of the .dat files into .vob format, hence takes a lot of disk space.
Can anyone please help me in this regard
knoppix is offline
Old 09-09-2006, 06:00 PM   #2 (permalink)
nil_3's Avatar
Default Re: VCD on DVD
Originally Posted by knoppix
Hi Friends,
...when i try select the media type as DVD disk and add video to the compilation, it starts the conversion of the .dat files into .vob format, hence takes a lot of disk space.
Your selection of media type as DVD disk is allright but instead of clicking on DVD-Video you should select "Make Data-DVD". That will write your .DAT file without conversion.
One more thing. Instead of writing .DAT files, you should write them in .MPEG. Nothing to do, just rename them. It will make your written files more compatible with Players.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 09-09-2006, 06:09 PM   #3 (permalink)
Thanks a lot Nil
My understanding by ur reply is that i have to simply rename the .dat files to .mpeg and burn it as data DVD.
But if i do so, will these DVD's be compatable with DVD players ?
Thanks in advance.
knoppix is offline
Old 09-09-2006, 06:13 PM   #4 (permalink)
No they won't.
drvarunmehta is offline
Old 09-09-2006, 06:18 PM   #5 (permalink)
then is thr any other solution ?
knoppix is offline
Old 09-09-2006, 06:36 PM   #6 (permalink)
You should just let it convert to VOB format. There won't be much loss in quality if any.
Old 09-09-2006, 07:54 PM   #7 (permalink)
but VOB format consumes a lot of disk space. I want to convert it into .dat format so that i can reduce the no of CD's.
knoppix is offline
Old 09-09-2006, 08:25 PM   #8 (permalink)
The Devil
blackpearl's Avatar
This might help you
http://club.cdfreaks.com/showthread.php?t=138405
blackpearl is offline
- by Krow
