Old 12-12-2004, 08:07 PM   #1 (permalink)
QA Juggler
saROMan's Avatar
Default AutoPatcher XP..
well while browsing the DVD..i found out bout it....and on clicking on it it asks place to extract the files....but after d/l 7/8MB out of 400odd MB..it starts giving error ....Broken Files...i have tryed to extract it using WinRAR ...but no use..same error there also..so is the Installation Corrupt? .. or the DVD am haing is Corrupt?? ..does any 1 else has the same problem???
सारोमान
saROMan is offline
Old 12-12-2004, 08:54 PM   #2 (permalink)
King of my own Castle
freshseasons's Avatar
Naaa just your Dvd is damaged. But if you need that software so much you can easily download it from the net .
Best luck
freshseasons is offline
Old 12-12-2004, 10:15 PM   #3 (permalink)
Aditya11's Avatar
Yes, I am having the same error and I dont think my DVD is damaged AT ALL!
The size of this autopatch prevents me from even downloading it...I hope Digit gives it on next month's DVD (with proper testing).
Aditya11 is offline
Old 13-12-2004, 12:09 AM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Post here
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
