LinkBack (11) Thread Tools Search this Thread Display Modes
Old 08-09-2006, 07:22 PM   11 links from elsewhere to this Post. Click to view. #1 (permalink)
Formerly Spashy
Sparsh007's Avatar
Question How To Change Color Of Taskbar.
how can i change the coour of my taskbar(blue part here)
World Cup T20 News: http://wct20talk.com
Sparsh007 is offline
Old 08-09-2006, 07:50 PM   #2 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
Default Re: Question
Right click
properties
appearance
advance....adn now play with the colors u want and what u wanna change and how u want ......if that is what u wanted
wizrulz is offline
Old 09-09-2006, 10:43 AM   #3 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: How To Change Color Of Taskbar.
No, @wizrulz, there is no option to change the taskbar color over there in xp pro
But at http://groups.google.co.in/group/mic...bc23f227f4d36a
Originally Posted by davey
Ok
For beginners you can change to either 3 colours.
Right click on desktop and select properties, then select
appearance tab, then select in the Colour Scheme filed,
either Luna blue, luna silver and luna green.
You can however change it to basically any colour using
Tgsoft Style XP, located from their website.
http://www.tgtsoft.com/download.html and select Style
XP from there, its shareware which means you have to pay
for it eventually.
For advanced users, use the UXTheme patcher utility. This
requires changing around both the uxtheme.dll in both the
dll cache(hidden system folder) and in system32 folder.
Advance users only.
Then go to sites like http://www.themexp.org/ and then
you can use any theme you want and have basically any
colour you want.
-Davey
A bit tough piece of software though.
Also can try http://www2.freedownloadscenter.com/...heme%20Manager
http://download.softpedia.com/softwa...ce/uxtheme.zip
Life is too short. Have fun.
ilugd is offline
Old 09-09-2006, 01:56 PM   #4 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can change it using Resource Hacker.
Just open the %windir%\Resources\Themes\Royale\Royale.msstyles. in Resource Hacker and change following 2 BITMAPs:
ROYALE_TASKBARBACKGROUNDVERTICAL_BMP
ROYALE_TASKBARBACKGROUND_BMP
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-09-2006, 04:57 PM   #5 (permalink)
ilugd's Avatar
That's good vishal.
Where do you get your goddamn info from??
ilugd is offline
Old 09-09-2006, 05:56 PM   #6 (permalink)
jz2linkinpark's Avatar
hey cool theme!
can i know where to get it?
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 09-09-2006, 07:22 PM   #7 (permalink)
Formerly Spashy
Sparsh007's Avatar
thnx everyone specially vishal,ilugd
@jz2linkinpark were you talking about mine??
Old 09-09-2006, 07:31 PM   #8 (permalink)
Microsoft MVP
@ilugd
thnx buddy
@jz2linkinpark
Its Royale theme which comes with Windows MCE. But u can d/l it from here. It has come in DIGIT CD/DVD many times.
Old 10-09-2006, 12:10 AM   #9 (permalink)
SE><IE
Posts: n/a
Thanks vishal, But I tried changing the hue of the above-mentioned bitmaps(after saving them, ofcourse) then I replaced the original royale.msstyles with the modified one. I changed the theme from desk.cpl to something else and back to "royale". The result-I got classic windows kinda style i.e. damn dull grey (98 style). Is there anything else (maybe WFPS) to do?
Old 10-09-2006, 01:20 AM   #10 (permalink)
Microsoft MVP
hv u patched the uxtheme.dll file???
Old 10-09-2006, 02:27 AM   #11 (permalink)
SE><IE
Posts: n/a
oops I forgot , will do it and try
EDIT:
didn't work out Can you give some detailed info?
I patched up the uxtheme.dll and then applied the modded royale theme, but the result was same
Edit2: Worked
Old 10-09-2006, 03:24 AM   #12 (permalink)
Microsoft MVP
Make sure that first u change the windows theme to something else, then edit the Royale msstyle!
2nd thing, Save the edited Royale msstyle somewhere else, and then run from there by double-clicking on it.
I'm not sure about this msstyle coz its from Microsoft, may be they put some checks for file changes? I hv changed many msstyles using the same method in past.
Old 10-09-2006, 11:49 AM   #13 (permalink)
Formerly Spashy
Sparsh007's Avatar
i installed the patch and this happened
now what to do??
__________
btw my os is windows xp mce if reqd.
Old 10-09-2006, 11:50 AM   #14 (permalink)
Anand_RF's Avatar
It's reverted to the windows classic theme. Goto desktop, right-click >> Properties. Appearance tab, and choose royale edited if its there. Otherwise goto where you edited and saved the royale-edited theme, double-click and choose apply.
Anand_RF is offline
Old 10-09-2006, 12:00 PM   #15 (permalink)
Formerly Spashy
Sparsh007's Avatar
the visual styles could not be loaded becuse the file failed to load
Old 10-09-2006, 12:50 PM   #16 (permalink)
ilugd's Avatar
the file seems to have been corrupted, so xp is unable to load it.
vishal, will be back to the rescue, i guess. (After all, he broke it.. <grin>)
ilugd is offline
Old 10-09-2006, 02:33 PM   #17 (permalink)
SE><IE
Posts: n/a
same thing happened to me >>
You gotta patch up the uxtheme.dll file(i.e, replace the original with patched up version) and then modify the theme
proof:
Edited on 10-09-06 at 11:11 pm
does anybody know how to bring up the transparencies ?
Old 22-01-2007, 03:32 PM   #18 (permalink)
grear tut...
ismart is offline
Old 22-01-2007, 05:55 PM   #19 (permalink)
Pragadheesh's Avatar
Post Re: How To Change Color Of Taskbar.
Check out this thread(especially vishall's tutorial)...
vishal
Pragadheesh is offline
Old 21-07-2008, 08:31 AM   #20 (permalink)
Originally Posted by Sparsh007 View Post
Help me!!! I am not able to change the grey taskbar in XP SP3. I tried UXtheme patcher. It doesnt help. I tried Style Xp in vain. It changes style and other taskbar properties except the grey taskbar of start menu. Please help me....(blue part here)
I made changes in Display properties>apprearance>silver etc. That too didnt work. What could be the reason, please advice me.
joedc is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/35944-how-change-color-taskbar.html
Resize the taskbar - AutoIt Forums This thread Refback 23-08-2011 02:19 PM
change color taskbar - Google Search This thread Refback 02-06-2011 11:24 AM
How Do you change the colour of a taskbar? - Yahoo! Answers This thread Refback 19-05-2011 08:51 AM
Resize the taskbar - AutoIt Forums This thread Refback 06-04-2011 10:13 PM
[Resolved] How to modify a single display theme color? This thread Refback 05-03-2011 10:17 PM
????????????? This thread Refback 02-02-2011 11:14 AM
How Do you change the colour of a taskbar? - Yahoo! Answers This thread Refback 17-12-2010 06:02 AM
change taskbar color - Google Search This thread Refback 03-10-2010 07:22 PM
Resize the taskbar - AutoIt Forums This thread Refback 27-08-2010 01:04 AM
How Can I get a Pink Taskbar ? - Yahoo! Answers This thread Refback 09-07-2010 09:54 PM
Resize the taskbar - AutoIt Forums This thread Refback 17-06-2010 08:55 PM
- by Krow
