Old 08-09-2006, 07:08 PM   #1 (permalink)
k_blues24's Avatar
Arrow What is Crack?
I know this is a foolish question, but still I want to know What is a Crack & how it works?
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
Old 08-09-2006, 07:17 PM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: What is Crack?
Crack is a small piece of program that generally is made so as to bypass all Piracy security measures of a particular software. They usually come in 3 types.
1. Direct EXE replacement:
You get a cracked exe which you replace with that of the original and your software usually acts as a paid then.
2. Patching:
A small utility patches your program's main exes and other files with some extra bytes, or in some cases, removes some bytes and makes it a full-version
3. Direct Serial/Keygen method:
Sites provide a brute-forced or exploited key or even a random key generator for specific softwares, that one can use in the software's "Enter key to unlock full version" dialog box and unlock the full version of the software.
If you wish to read on on this crucial Software piracy topic, I suggest you go to http://en.wikipedia.org/wiki/Software_cracking .
Whatever you do, never google for 'crack'
Harsh J
www.harshj.com
QwertyManiac is offline
Old 08-09-2006, 07:40 PM   #3 (permalink)
GUNNING DOWN TEAMS
wizrulz's Avatar
CRACK....as everyone knwo its a tool/ s/w to make s/w work illegally.....
When a program is written....say a s/w, game programmers, testers , puposely have an opening kept in programs at certain points..so that if any changes and/or upgradation is to be doen can be done easily....these opening is used by crackers programs to enter the software......
wizrulz is offline
Old 08-09-2006, 07:42 PM   #4 (permalink)
good one buddy......... very coool wat to respond........ thx 4 the explanation
2. Patching:
Saket Parekh is offline
Old 09-09-2006, 01:59 PM   #5 (permalink)
EagerBeaver's Avatar
Looks interseting. So wher do you get this cracks ??????????????????????????
FREEDOM ROCKZ...ATTITUDE RULZ
EagerBeaver is offline
Old 09-09-2006, 02:08 PM   #6 (permalink)
dOm1naTOr's Avatar
This forum is against any cracks/hacks nd piracy. Better u dun ask that qn...just jokin.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 09-09-2006, 06:10 PM   #7 (permalink)
Commander in Chief
Thats one question which no one really knows to answer. But the fact is, at this forum if you look beyond its layers
Harsh J
www.harshj.com
Old 09-09-2006, 06:16 PM   #8 (permalink)
GaurishSharma.com
gary4gar's Avatar
well google contains information to create a bomb, so cracks are small things.
gary4gar is offline
Old 09-09-2006, 06:19 PM   #9 (permalink)
thanx, nice info
sanju is offline
Old 09-09-2006, 06:43 PM   #10 (permalink)
Distinguished Member
anandk's Avatar
Talking
ahem actually this is one question, whose answer EVERYONE knows,
but pretend NOT TO KNOW or DONT KNOW HOW TO ANSWER
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 09-09-2006, 06:46 PM   #11 (permalink)
crack patches software by replacing exes
ghanshyamrathod is offline
Old 09-09-2006, 07:21 PM   #12 (permalink)
Pragadheesh's Avatar
Post Re: What is Crack?
but my friends got Prince of Persia 2thrones game in which if u double click the exe file ,which takes u to d game, it checks if the power cable & bus is plugged into the cd drive, if so the game doesnt get launched.
so in order to play that game one must remove the power cable & bus connections of the cd drive.
Is this any kind of crack?
I COULDNT PLAY THE GAME AS MY GRAPHICS CARD DIDNT SUPPORT IT(
Pragadheesh is offline
Old 09-09-2006, 09:12 PM   #13 (permalink)
Thor's Avatar
Yes. I hv heard of the problem. It has to do somethging with the new Starforce CD protection scheme implemented. Though now a better crack is available .
Now even softwares to make patch is even available, i used once a tool called PatchEngine. It was not very effective and worked in case of very select S/Ws
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 09-09-2006, 09:44 PM   #14 (permalink)
The Devil's Advocate
iMav's Avatar
rightly said ... we dont wanna get banned
http://beingmanan.com
iMav is offline
Old 09-09-2006, 09:47 PM   #15 (permalink)
dOm1naTOr's Avatar
yaa thats the truth. Some may be wizards, but pretend to be innocent.
G3: XPS M1530 |
FZ 16.
Old 09-09-2006, 10:09 PM   #16 (permalink)
Commander in Chief
To hell with Software Piracy, better become a programmer and go for Open Source/Freeware programs.
Games, try Gunz Online, Alien Arena, Legends, great MMORPG games.
Cracking is dumb, waste of time and bad to the world, which includes even you.
Harsh J
www.harshj.com
Old 09-09-2006, 10:50 PM   #17 (permalink)
Thor's Avatar
I think because there is cracking, software security will only rise. There will always be a bad apple among the goodones. So better be prepared, than live the illusion of "No Cracker" world.
Thor is offline
- by Krow
