Old 07-09-2006, 10:33 PM   #1 (permalink)
Just Do It
Charley's Avatar
Default RM to AVI / MPG convertor
I have lots of real media files. I need to convert them to avi or mpg formats. NO WMV.
Is it possible? if yes give me a LINK for the software convertor.
Charley is offline
Old 07-09-2006, 10:59 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: RM to AVI / MPG convertor
It'll help u:
http://www.boilsoft.com/rmconverter.html
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 07-09-2006, 11:12 PM   #3 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
See here RM to AVI/MPG converter
rakeshishere is offline
Old 08-09-2006, 01:01 PM   #4 (permalink)
Just Do It
Charley's Avatar
Before I donwload, I have a doubt.
For eg, I have a Real Media file of 70 mb and I convert it to avi / mpeg , will the size remain the same or increase or decrease?
Charley is offline
Old 08-09-2006, 05:11 PM   #5 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
well the size will depend on compression ull be using..for mpeg it shud be fairly same....but avi i doubt....
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 08-09-2006, 08:32 PM   #6 (permalink)
HELP AND SUPPORT
Avi it will decrease ...but mpeg the size may inrease/decrease depending on the quality u want but it will obviously be more than avi
Old 09-09-2006, 08:55 PM   #7 (permalink)
Pragadheesh's Avatar
Post Re: RM to AVI / MPG convertor
avi compresses a file with no loss of quality. njoy using it..
Pragadheesh is offline
Old 09-09-2006, 08:59 PM   #8 (permalink)
18 Till I Die............
Maybe Media Coder can help you.
http://www.bash.org/?258908
mehulved is offline
Old 09-09-2006, 09:02 PM   #9 (permalink)
Thor's Avatar
I hv used Plato video Converter for some time. And I am happy with it.
http://www.dvdtompegx.com/html/videoconverter.html
Beware of my Wrath Mortals, Thou hast no choice.
Thor is offline
Old 12-09-2006, 01:17 PM   #10 (permalink)
Just Do It
Charley's Avatar
Wow, I have recvd a lot of links .....
Pretty difficult to select the best one.
Charley is offline
- by Krow
