Old 07-09-2006, 08:35 PM   #1 (permalink)
Default formating hard disk keeping all the installed programmes
I have xp home , the problem is that i need to reformat my hard disk and I have a couple of programmes installed which I had got from friends and don't have their backup setup files. can somebody tell me a way in which I can reinstall xp without loosing those programmes i.e these programmes remain installed.
cybertooth is offline
Old 07-09-2006, 08:40 PM   #2 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Default Re: formating hard disk keeping all the installed programmes
R the setup files in ur directory in which windows is located? if it is then 4 get it and If in some other drive instead of doing a fresh install of xp do a reinstall..(u will get that option during the xp-installation)
rakeshishere is offline
Old 07-09-2006, 09:01 PM   #3 (permalink)
Anand_RF's Avatar
Yes what he said. Choose repair option. But it MIGHT not be able to solve the problem because of which you're reformatting, there is a small chance the problem can continue. The best thing you can do is to download the setup file of the 2 programs you need.
Anand_RF is offline
Old 07-09-2006, 09:03 PM   #4 (permalink)
gooby pls
Third Eye's Avatar
Where are programmes installed ?
In WinXp Directory or any other ?
Third Eye is offline
Old 08-09-2006, 02:49 PM   #5 (permalink)
The Researcher
I don't know why you want to format your HDD. If it is due to virus, better forget your programmes. But if not, use Acronis True Image and make an image of your drive containing the OS and other programmes. Then format and using the Acronis Boot CD, restore that image. This is the simplest and fast way bringing your PC to its pristine glory without having to go through all the hassles of installing drivers, searching and putting in different cd's for installing different programmes, etc.
Ramakrishnan is offline
Old 08-09-2006, 05:08 PM   #6 (permalink)
"The RaCaLaNGeL"©
romeo_8693's Avatar
@rama
then wats the point in formatting???probably he has a system problem...or may be he feels his installation is become dirty.....i think he is askin whether u can back up just the installed program folder and still make its work...
well if that is the case then,some small prog do work...but the once which depend on registry then they 'might' not work...best is try repair!!!
Without sorrows happiness would be boring!
romeo_8693 is offline
Old 09-09-2006, 11:07 AM   #7 (permalink)
k_blues24's Avatar
First creat the restore point then Back-up the desired (all drives) drive ( so all reg. entries will be safely copied )
Talk less than u know, Show less than u have ;)
Yesterday is History. Tomorrow is Mystery.
Today is a Gift, that's why it is called as
The PRESENT.
k_blues24 is offline
- by Krow
