Old 11-12-2004, 11:33 PM   #1 (permalink)
Default can 2 bluetooth dongle can connect 2 each other
if they r connected to different personal computers in their range e.g.
2 pcs in 25 metre range
vividh is offline
Old 12-12-2004, 11:14 AM   #2 (permalink)
I would also like to know ....... if any one knows plz post reply asap. thanx
Strength of A MaN was Once mEasUred with his
BrAiN & bRawN ............ NoW its MeAsureD with hiS RAM & ROM !!!!
justo is offline
Old 13-12-2004, 12:46 AM   #3 (permalink)
they should b able 2 connect....they will recognize each other as 2 bluetooth devices....and the range is 10m, not 25m....if it is not possible, then i would also like 2 know y not....
do u hav this setup??? or r u just asking out of curiosity?? if u hav the hardware, then go ahead and try it out....
Nemesis is offline
Old 13-12-2004, 02:50 PM   #4 (permalink)
in ur bluetooth options select "search for other devices in range"
also put it on "let this computer be discovered by other devices "
the options could be "paired devices" " all devices" and one more i dun rem
i suggest u PAIR the devices and save them .. and select "Connect without askin when this device is in range" option !
for pairing u need to set up a pin code which should be asked automatically
once setup and paired uc an select the services u wanna run
eg "OBEX file transfer",
bluetooth networking or bluetooth modem ... or somethign li that connected to bluetooth internet sharing or something
"bluetooth SYNC fucntion"
etc
click on the services u want installed ..
and simple
ur up and runnin !
should be simple enuff once u start fiddling ard with ur bluetooth settings !
No Mercy, No Limits.
theraven is offline
Old 14-12-2004, 12:26 PM   #5 (permalink)
King of my own Castle
freshseasons's Avatar
I have being using Bloetooth adaptor since few months to surf net...stream videos and Pc synce and file transfer .( 100 meteres since got Class A Adapter @ 1 Mb)
Check my Link here ..this dates too August 17 2004 :
Its titles : Cheap Wireless network under 2K ..
http://www.thinkdigit.com/forum/view...ight=bluetooth
Enjoy
freshseasons is offline
