Old 05-09-2006, 11:25 PM   #1 (permalink)
Exclamation HELP!!! dvd conversion
I want to convert the dvd files(.vob format) to real media video format(.rmvb)
... Can any one please tell me the required software to convert to.rmvb format !!!!!!!!!
nihar16 is offline
Old 06-09-2006, 10:34 AM   #2 (permalink)
Come get Some
DukeNukem's Avatar
Smile Re: HELP!!! dvd conversion
Use The AVS Video Converter for that (to any format conversions .3gp .avi .wmv .mpg etc)
BUt is Say BUT
its not free and it will cost u a fortune( He He).
and the demo or trial on will embedd a watermark in the converted one
DukeNukem is offline
Old 06-09-2006, 10:39 AM   #3 (permalink)
Google Bot
Pathik's Avatar
Default Re: HELP!!! dvd conversion
Try xilisoft
Pathik is offline
Old 06-09-2006, 10:40 AM   #4 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Cool Re: HELP!!! dvd conversion
Why do u want to convert VOB into RMVB,
Video Quality will be at its poorest an Sound Quality will be poorer
techtronic is offline
Old 07-07-2007, 01:35 PM   #5 (permalink)
This is right.If you want to convert then you may do it in DivX, x264 or XviD etc. formats.Use MediaCoder for that.Its free and open source.Very good software.
Binit is offline
Old 07-07-2007, 09:34 PM   #6 (permalink)
slugger's Avatar
AFAIK direct conversion maynot b possible with freeware
wat u can do is convert d *.vob file into *.avi or *.mpg using
SUPER
then using Easy RealMedia Producer 1.94 u can convert it to *rmvb format
slugger is offline
Old 11-07-2007, 09:39 AM   #7 (permalink)
You can try to use SuperDVD Video Editor,It's a free software,But it's very powerful.
a3721 is offline
Old 11-07-2007, 04:26 PM   #8 (permalink)
slugger's Avatar
but it doesn't seem 2 do any rmvb conversion
welcome 2 d forum buddy
appreciate d fact dat u trying help d original poster
but u shud have read d original post a little more carefully as d poster wanted 2 do vob ->rmvb conversion which ur it doesn't seem 2 do
make it a habit 2 read d original post carefully and any subsequent posts even more carefully b4 adding ur own posts
slugger is offline
