7600GS is not just Rs. 6500. It's atleast 7.5-8k.
I presume you have 128+512 MB RAM. Use the 512 MB chip you already have and get another 512 MB one (Rs. 2200) if your budget permits.
If you can extend your budget to include the 3500+, then do so otherwise settle for the 3000+. But don't compromise on the graphics card.
You can check the prices here
http://www.deltapage.com/
