Old 04-09-2006, 12:06 AM   #1 (permalink)
Cool Registry Cleaners: Which one?
Guys! I have heard a lot about registry cleaning which if negotiated can lead to performance issues,so I decided to get one and start cleaning up.So please tell which one is best(other than full system suites such as System Mechanic or any other)suited for Windows XP.I know some..
1)Registry Mechanic
2)Reg Cleaner
3)Reg Clean
4)Reg Fix
5)Windows Registry Repair Pro
6)CCleaner ...etc
7)Any other if you know
But I haven't tested anyone.So please tell me the best in this business to clean up Registry from this list or other than this if you guys have experienced.
rakesh-the gilli is offline
Old 04-09-2006, 12:26 AM   #2 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
Default Re: Registry Cleaners: Which one?
tune up utlities and CCleaner will do fine.
n00b forever...
~Phenom~ is offline
Old 04-09-2006, 12:34 AM   #3 (permalink)
go_gamez's Avatar
yup tune up utilities 2006 is the best....though it will give u a heart attack after the frst scan with some 1000s of registry and other problems...later on it will be smooth..
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 04-09-2006, 12:57 AM   #4 (permalink)
knight17's Avatar
The registry cleaners in System Mechanic and Reg Cleaner works well.
"It's not a silly question if you can't answer it." Sophie's World [ http://en.wikipedia.org/wiki/Sophie's_World ]
knight17 is offline
Old 04-09-2006, 12:22 PM   #5 (permalink)
Distinguished Member
anandk's Avatar
ccleaner is a good freeware www.ccleaner.com
but of the lot i find ace utilities, tune-up having good registry cleaners.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 04-09-2006, 01:01 PM   #6 (permalink)
!FREEWARES!
Akshay's Avatar
I'd suggest u use WinXP Manager. Though not free, u wont need any odr tool to tweak xp, registry, etc. after installing WinXP Manager
MBP 13.3";
PC: Core i-5 2400, Intel H67, GSkill 4GB DDR3, Sapphire 6850 Toxic, 1TB HDD, Samsung P2370
Steam (Cod-MW2 only) - akshay81
Akshay is offline
Old 04-09-2006, 02:49 PM   #7 (permalink)
royal's Avatar
Cool Re: Registry Cleaners: Which one?
I think RegCleaner is the best free alternative
and yeah...TU is also good
royal is offline
Old 05-09-2006, 11:37 AM   #8 (permalink)
well i use the combination of system mechanic 5 and registry mech..
it works fine for me...
thadhanihemant is offline
Old 05-09-2006, 11:58 AM   #9 (permalink)
JGuru's Avatar
@Rakesh, If you want to read about the Top10 Registry Cleaner reviews, then click here
JGuru is offline
Old 12-09-2006, 02:05 PM   #10 (permalink)
System Mechanic 6.x pro is one of the best system tools program, it is one solution for all your requirements.
slagad is offline
Old 12-09-2006, 10:37 PM   #11 (permalink)
nishant_nms's Avatar
I use TweakNow Registry Cleaner for my XP x64
nishant_nms is offline
Old 12-09-2006, 10:40 PM   #12 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
i use ccleaner
vijay_7287 is offline
Old 13-09-2006, 12:58 AM   #13 (permalink)
GaurishSharma.com
gary4gar's Avatar
ya as all say go for ccleaner
gary4gar is offline
