Old 11-12-2004, 11:03 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Extract song ! ! !
how do u extract a song from a dat file ???
so that i dont have 2 waste time in download the song ...
bt software freeware mangata hai ...
ax3 is offline
Old 11-12-2004, 01:17 PM   #2 (permalink)
Another Brick in the Wall
drgrudge's Avatar
u can use a VCD cutter or VCD clipper or that....
as for only extracting the song only(not video ) , i think it has already been discussed , search! ( posted by swatkat, or PM him, he know this kinda stuff).
drgrudge is offline
Old 11-12-2004, 02:06 PM   #3 (permalink)
try out Virtual Dub!!!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 11-12-2004, 02:36 PM   #4 (permalink)
Ethan_Hunt's Avatar
Lets Make a Correction Here.....He asked for .Dat file Cutter which is Typically a Mpeg 1 compression file and Wont be directly supported by Virtual Dub Which mean its has to be First Converted Into .Mpg File.....Btw Ax3 i suppose this query has been discussed earlier and may be u had posted the same query ....anyways Vcd Cutter is The best and the most simple for ya....u Can cut The Desired Scene And save It in .mp3 format.....but Man one bad news for ya It Ain't a "freeware"....So Shayad Original Lena Padega......... 8) Or Pm Me For a Solution Mate.....
Ethan_Hunt is offline
Old 11-12-2004, 07:47 PM   #5 (permalink)
Try using Power Video Convertor. It can extract audio from almost all the video formats including DVD and Divx. There nothing hard....just a single click will do the job. It also has other great features...you can find with the December Digit issue.
[lokesh] is offline
Old 12-12-2004, 12:16 AM   #6 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
<Sigh> ...
I posted it at the wrong place I think .. ...
Extracting Song from vedio
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
