02-09-2006, 07:54 PM
A flash based web designer please!!!
Hi friends,
I want to make a website for personal purposes. But I am not much aware of the codings and other stuff in flash. So can you suggest me a software which will help me to make a flash website(with templates)?
.dk
02-09-2006, 09:02 PM
18 Till I Die............
Re: A flash based web designer please!!!
Why do you want to prepare a flash site. Flash site will just drive away many visitors due to the long loading times. Also, those not having flash player plugin installed will be most likely to go away from the site.
Anyways, I don't know much about flash templates. But, google should give you a lot.
http://www.bash.org/?258908
02-09-2006, 10:23 PM
Wise Old Crow
if u know how to optimize flash then go ahead. else just create a static site.
for flash making s/w i suggest u try swishmax. i m using it atm.
02-09-2006, 10:39 PM
I see right through you.
I strongly advise against making a flash only website. There were times when I thought it would be cool, and it does look cool, but it is discriminatory. For example, some versions of flashplayer are not available for linux users, and some people don't even use a graphical browser. Your best course of action would be to create the website using standard XHTML and CSS. There are plenty of nice effects you can implement while remaining standards compliant.
I didn't make the world, I only try to live in it.
http://lucentbeing.com
-- Sykora --
02-09-2006, 11:04 PM
Also, if I remember right, flash sites don't score well SEO wise though I guess that's not your concern.
03-09-2006, 08:10 AM
Nowadays, that's _everyone's_ concern.
-- Sykora --
03-09-2006, 10:26 AM
eWebGuru
Since you are making site for personal purpose and do not have any commercial angle. You can go for flash site. There are many flash template available on net try searching in google. You can also use swish software through which you can create cool effects. Trendy Flash Intro builder is also good software for web development.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
03-09-2006, 11:20 AM
True Techie
what about MACROMEDIA Dreamweaver..?
03-09-2006, 11:23 AM
That's "Dreamweaver" and that's not for flash development.
-- Sykora --
03-09-2006, 05:33 PM
For flash, either you will have to get Macromedia Flash, learn flash and make it OR look around the web for free flash templates/clips.
I guess the second option is far better  and you have google to get going!
04-09-2006, 12:36 AM
^^Thats true. Learn it or hunt for readymade ones
04-09-2006, 12:55 AM
I also won't recommend a flash only website,if you really need one try using Trendy Flash site builder or Swish Max
"It's not a silly question if you can't answer it." Sophie's World [ http://en.wikipedia.org/wiki/Sophie's_World ]
04-09-2006, 08:34 AM
I read all your comments. But as I am making it for purely personal purposes, I think flash is going to be my choice. There wont be much visitors except my friends and relatives. It is not meant for business purposes. Also most of my friends have broadband.
I dont want to spend much on web designers. Is there any free designers?
.dk
05-09-2006, 03:25 PM
Google is your best friend in this case
There are many free flash based templates on the web. So get going with google!
You can also have a look at http://myfreetemplates.com and http://www.freetemplates.com.
05-09-2006, 07:39 PM
An Esoteric Geek
You can use Sothink Glanda from SourceTec Software
This is a flash creating software and no coding required..!! You can create flash banners and all the components in seconds
Reason: Automerged Doublepost
09-09-2006, 09:58 PM
Can you please give me the download site? I tried googling but ended up with negative results.
.dk
09-09-2006, 10:00 PM
http://www.sothink.com/ the first result I get when I searched for SourceTec Software.
Search this Thread |
