Old 02-09-2006, 05:03 PM   #1 (permalink)
Tux Fan
shaunak's Avatar
Default Avast Stratup problem
Imm using avast and zonealarm. although windows starts up fine, it takes a long time for avast to initialize during which it displays a strikeout over its tray icon.on right clicking it shows an rpc error. it takes nearly two minuites for it to initialize during which i cant use my system.
My startup items are:
>zlclient [zonealarm]
>ctfmon.exe [office bar]
>avast!
Help!
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 02-09-2006, 06:07 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Avast Stratup problem
It happens with me also several times.
When I login, avast shows a strikeout over its icon and after a few seconds it starts rolling
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 02-09-2006, 07:31 PM   #3 (permalink)
The Devil
blackpearl's Avatar
Yes, that happens. Try doing this. Click on program settings>common and disable "Test memory during startup". This will speedup a bit.
blackpearl is offline
Old 02-09-2006, 09:09 PM   #4 (permalink)
deepgeek2's Avatar
Well... I think here startup refers to the Scanner and not the resident shields....So, do you really think Avast checks memory after win login?
Pllleeeeeeeeaaaazzzzzzzzzzzzzzzzzzzeeeeeeeeeee add to my Repu points if you think i was helpful.
deepgeek2 is offline
Old 03-09-2006, 10:07 AM   #5 (permalink)
Distinguished Member
anandk's Avatar
za is usually the first one to startup. it does take a litle time. then avast startsup. my experience hac also been the same. so i think its normal. nevertheless u can try to use 'microsoft bootvis' or 'driverheaven tune-xp' to make ur booting process a little faster.
the option is 'test memory during applications startup". i may be wrong but only resident protection starts up after booting. unchecking this may no help u. its only during starting the avast application interface that memory scan is not done if u uncheckthis box.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 03-09-2006, 02:24 PM   #6 (permalink)
Microsoft MVP
The problem is not to make the startup faster, but the main problem is why avast! shows "strikeout over its icon" sometimes at startup? it doesnt occur all the times but sometimes. I think it checks something and then starts...
Old 03-09-2006, 02:38 PM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
if you dont get any solution, then try AVG Free, i'm using it on my Desktop as well as Laptop, without any issues like this.
the start-Up time for my Desktop is around 15 seconds after "LogOn screen" & if i disable the ZoneAlarm Pro, then its less than 10 seconds!!
full start-up time (right from when the Power is turned ON) is around 40-50 seconds.
ASUS K53SV SX520D + BF3
s18000rpm is offline
