Old 02-09-2006, 03:13 PM   #1 (permalink)
Google Bot
Pathik's Avatar
Default PC FOR 35K.. urgent..
a friend of mine wants to take a new pc....budget 35k
its not for gaming...but for extensive video/audio/photo editing.....
hows this...
proccy... conroe e6300 or e6400
motherboard D975XBX or DP965LT(pls gimme ny other mobo wich is good for the above proccys.)
+1 gb(2*512 as it supports dual channel) ddr2 533mhz ram(kingston or hynix) or ??...
+a 5.1 sound system... or whatever is good...
also i want a atx cabinet + a 400w psu... pls recommend me the good ones...
within abt 2-3k...
also i want a 17" lcd monitor.... pref samsung syncmaster xxx(wich one??)
also do 2.1 speaker systems work with 5.1 onboard sound.... i want a good speaker sys for abt 2k...
can som1 gimme the exact prices in mumbai for the above config....
and finally the budget is 35k...
gimme ny config u think is good for this price...
also hows this...
mobo asus a8ne
proc. amd athlon x2 3800+
ram ddr 400mhz 1gb...
GC 7600 gs...
i think i shd take the conroe one instead of the amd one....
__________
suggest me the tft-lcd monitor + a 2.1 sound sys for abt 15k if poss...
__________
also a hp printer/scanner for abt 3-4k..
Pathik is offline
Old 02-09-2006, 05:43 PM   #2 (permalink)
NEXT BILL GATES
mihirvashist's Avatar
Cool Re: PC FOR 35K.. urgent..
hows this...
within abt 2-3k...
also hows this...
mobo asus a8ne
GC 7600 gs...
__________
__________
do you seriously think that that config will set you back for 35k...
i mean even i have done a lot of research abt the market prices and configured systems for my relatives but i don't think you can get all that in 35 k...
i can't give you prices for mumbai but still even the best and cheapest options you have given would make the price of that pc above 35 k (i think so)
so plz consider ur budget again....
and yes you have forgotten hard drive ,dvd drive,key board,mouse,graphic card(even photo editing requires good graphic)
KNOWLEDGE IS POWER!!:-)
mihirvashist is offline
Old 02-09-2006, 07:02 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Default Re: PC FOR 35K.. urgent..
i jus wanted to know the prices of those components... cos i know the prices of hdd,dvd rw,kbd etc....
neways hows this....
athlon x2 3800+
asus a8ne
xfx 7600 gs
seagate sata 400gb
2*512 mb ddr 400mhz ram..
MS internet kbd
logitech optical mouse
samsung 17" lcd mon
(now jus sugg me the cab+ps+spkr sys+printer/scanner) such that it comes under 35k..
Pathik is offline
Old 02-09-2006, 07:28 PM   #4 (permalink)
The Devil
blackpearl's Avatar
If its for video/audio editing its best to go for an Intel processor, and in any case, Conroe rules!!!
blackpearl is offline
Old 02-09-2006, 07:53 PM   #5 (permalink)
Google Bot
Pathik's Avatar
but wat abt the budget probs..??
Pathik is offline
Old 02-09-2006, 09:15 PM   #6 (permalink)
deepgeek2's Avatar
You expect a CONROE based PC under 35K!!!
Pllleeeeeeeeaaaazzzzzzzzzzzzzzzzzzzeeeeeeeeeee add to my Repu points if you think i was helpful.
deepgeek2 is offline
Old 02-09-2006, 09:23 PM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
xfx 7600 gs
GS --> 6-7k
1024 ram --> 4-5 K
Harsh J
www.harshj.com
QwertyManiac is offline
Old 03-09-2006, 12:29 AM   #8 (permalink)
hey, if u want to buy this config only just increase ur budget for 10k, or eliminate speakers, etc etc which is nto useful for editting.
Intel Pentium triple3core 5.5Ghz intel original D502 GCCL Mobo 50 Gb DDR-4RajaPathar 2048Mhz 40 TBHDD EX12500XFX2GbDisplay SonyBlueRay+/-RW80.5GB
return_of_vengeance is offline
Old 03-09-2006, 10:55 AM   #9 (permalink)
The Devil
blackpearl's Avatar
Dude, the AMD X2 - 3800 and the Conroe E6300 costs the same, the later being Rs 500 costlier. You can get a Conroe supporting mobo for the same price you pay for the Asus A8NE. Only DDR2 memory will cost Rs 1000 more. So if you think you can get an AMD X2 for Rs 35K, then you can very well squeeze in a Conroe under the same budget. Drop the printer for now.
Old 03-09-2006, 11:02 AM   #10 (permalink)
Google Bot
Pathik's Avatar
ok the configs decided.....
now jus gimme good 2.1 speakers(creative or???) n a printer scanner(hp) such that it shd total 5k..
Pathik is offline
Old 04-09-2006, 12:47 AM   #11 (permalink)
Rebooting
Choto Cheeta's Avatar
BTW... can u guyess suggest only Procy + Mobo + RAM + 17 CRT" for 35k?? (Intel based pls...)
rebooting
ChotoCheeta.com
Choto Cheeta is offline
