Old 02-09-2006, 10:02 AM   #1 (permalink)
Lin Win Mac
ruthless's Avatar
Question PC Shutdowning
My pc config is as follows
AMD 64 3200+
ASUS A8N SLI DELUXE
512 MB ram
GeFORCE 6200TC
problem is when i connect my modem the machine keeps shutdowning.
is it due to hardware incompactability.
Modem is D-link.
PLz help me
ruthless is offline
Old 02-09-2006, 10:23 AM   #2 (permalink)
Welcome To The Jungle
sysfilez's Avatar
Default Re: PC Shutdowning
try upgrading all the driver, btw wat os r u using?
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 02-09-2006, 10:42 AM   #3 (permalink)
Lin Win Mac
ruthless's Avatar
Well i use xp. thanks 4 u r advice . i will try that
ruthless is offline
Old 02-09-2006, 12:20 PM   #4 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
Shutdowning?? Boy, you really need to brush up your English!
True, it is a driver problem, get the latest ones from the manufactueres site.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 02-09-2006, 12:29 PM   #5 (permalink)
Lin Win Mac
ruthless's Avatar
Red face Re: PC Shutdowning
should have used shuting down.(is it wrong again)?
I AM A FAN OF LOLA TV
ruthless is offline
Old 02-09-2006, 12:48 PM   #6 (permalink)
Distinguished Member
anandk's Avatar
...or perhaps 'downshutting'....
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 02-09-2006, 04:05 PM   #7 (permalink)
Lin Win Mac
ruthless's Avatar
May be that too
ruthless is offline
Old 02-09-2006, 04:16 PM   #8 (permalink)
sourav's Avatar
Cool Re: PC Shutdowning
wait! your computer shuts down when you connect your modem to your PC or when you connect to internet.
If your computer shuts down when you connect to internet. Then their are two problems . First may be the driver problem(check your modem vendor site) or a virus(TROJAN) ,get it checked by a good antivirus software.
First try that much!
We must accept finite dissapointment. But we must never loose infinite hope.
sourav is offline
Old 03-09-2006, 10:16 AM   #9 (permalink)
anandk's Avatar
ruthless in case u get such a msg : The system process lsass.exe terminated unexpectedly...The system will now shut down and restart...
then check this : system shutting down: please save all work in progress and log off
Microsoft® MVP
anandk is offline
