Well Assumig That Ur's Is a Sql Server Then use this code To try Connecting to Ur ASP
Dim objConn, objRS
Set objConn = server.CreateObject("ADODB.Connection")
set objRS = server.CreateObject("ADODB.Recordset")
objConn.Provider = "SQLOLEDB.1"
objConn.Properties("Persist Security Info").Value = "False"
objConn.Properties("User ID").Value = "WebUser"
objConn.Properties("Password").Value = "password"
objConn.Properties("Initial Catalog").Value = "MovieMSDE"
objConn.Properties("Data Source").Value = "ZBOROWSKI"
objConn.Open
See if this works.....
Or try This Link for A little help
http://support.microsoft.com/kb/176380/EN-US/ or
http://www.15seconds.com/Issue/001025.htm
