i have some .dat video files. but they don't play on my mp3 video player so i want to convert them to either mpg4 or mpg2, is it possible?
if yes suggest any freeware to do my job.
think u will never see the devil?
look in the mirror and u will see one!
I'm pasting the url of the site I got as my first google result. You can do a bit more googling and find a freeware, but for now - http://www.aoamedia.com/Convert_DAT_to_MPEG.htm
That's the tutorial but it has the link to the trial version of the software. Use that if you want.
Use ISO buster It is a freeware.Rightclick on .datfile,select "extract but filter only m2f2 mpeg frames".Select new file name ,save in a different location with .mpeg extension.
