I am using Tally 6.3 and have a problem with printing. Whenever I select quickmode printing, it takes 80 Columns by 66 Lines in A4 page as default. Now, when I print anything, lots of empty space is left both at the upper and the lower portions of the paper. I wanted to increase this 66 Lines so that the remaining empty space is also utilised. I explored a lot but couldn't find an option to increase this. Is there any method to achieve this.
Press F12>printing>general. there you will find an option for increasing or decreasing space on top and bottom of the document. You may use them. If this solves your problem, Please do post here. This you should do from the gateway of tally and not at the time of prinitng.
