Old 10-12-2004, 01:46 PM   #1 (permalink)
Default drop down menus
Recently I created a website for myself, I used the "select" HTML control and designed it, it's code is given below. Thee problem is that I can open up a page only when i change from one option to another but not when in the same option. Like in the "--header--" option in the menu is default selected, so if I press again header, it wont work since there is no change in the selection. Could anyone plz help me.
Also if u could tell me how to show the menu when we hover the mouse, I would be grateful to u.
<STYLE type=text/css>.networkbarselect {
FONT-SIZE: 11px; COLOR: #333333; FONT-FAMILY: Arial, Helvetica,sans-serif;BACKGROUND-COLOR: #f2f2f2
}</STYLE>
<SCRIPT language=JavaScript type=text/JavaScript>
function MM_jumpMenu(targ,selObj,restore){
var i;
i=selObj.selectedIndex;
selObj.selectedIndex=0;
eval(targ+".location='"+selObj.options[i.value+"'");
}</SCRIPT>
<select class=networkbarselect onchange="MM_jumpMenu('window.document',this,1)">
<option value=javascript:// selected>--header--</option>
<option value=http://www.yahoo.com>yahoo</option>
<option value=http://www.rediff.com>rediff</option>
</select>
sridhar8310 is offline
Old 10-12-2004, 03:49 PM   #2 (permalink)
The select control behaves in the way which you have mentioned. Everytime you select an option in the control certain events get triggered and hence it implements whatever is there in the code of the event called. In your case since the --header-- is already selected even if you select it again nothing will happen as no even gets triggered.
As for your second option use DHTML menus. They give you lot more flexibility and look very pretty too! Loads of tools are available to build them. Just google it!
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 10-12-2004, 05:11 PM   #3 (permalink)
Version 2.0
Deep's Avatar
http://www.dynamicdrive.com/dynamici...pmenuindex.htm
or
http://www.opencube.com/nav_online.html (pretty good)
i hope this solves your problem
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
