Old 30-08-2006, 03:11 PM   #1 (permalink)
jz2linkinpark's Avatar
Default how do i merge partitions?
hey all,
my computers hardrive had been divided into two partitions since the day i assembled it,when i asked my dealer why,he said that it was easier to reinstall windows or something like that,but now i can't even find enough space to install F.E.A.R in my master partition,so how can i merge the two of them(there is one drive but two partitions)
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 30-08-2006, 03:29 PM   #2 (permalink)
Alfansey06's Avatar
Default Re: how do i merge partitions?
what is your hard disk size and size of partitions
Alfansey06 is offline
Old 30-08-2006, 03:58 PM   #3 (permalink)
the hard disk is a samsung 40gb harddrive,the primary partition is a FAT32 9.75gb partition,and the secondary is a 27.50 gb ntfs
(\__/)
Old 30-08-2006, 04:04 PM   #4 (permalink)
Alfansey06's Avatar
cant you install F.E.A.R. in D: drive?
i know one way to merge both partitions but data will be lost. boot your pc from a win98 bootable cd and run fdisk. now you can delete both partiotions and make only one partition or change partiotion size. then format drives. install os again.
Old 30-08-2006, 04:05 PM   #5 (permalink)
think this will work,okay then thanks,btw.didn't i send you a pm regarding n91,didn't you get it?
(\__/)
Old 30-08-2006, 04:12 PM   #6 (permalink)
Alfansey06's Avatar
oh, i received it. i am in touch with you with other username
Old 30-08-2006, 04:18 PM   #7 (permalink)
whats that supposed to mean?pm me about it,not here!!
(\__/)
Old 30-08-2006, 04:32 PM   #8 (permalink)
Alfansey06's Avatar
^just joking. I am not interested in N91. I wanna confuse you. will send you pm (now i am serious)
Old 30-08-2006, 08:09 PM   #9 (permalink)
u can use partition magic. it has an option of merging partitions without loss of data. the process may take a few hours but its worth saving ur data.
What if this world really is Matrix?????
Techinator is offline
Old 12-09-2006, 02:16 PM   #10 (permalink)
You cannot mearge a FAT32 and NTFS partitions. Back up all data from the NTFS partition, re-format it to FAT32 and then use partition magic.
Otherwise convert the FAT 32 to NTFS and then merge using partition magic.
Command to convert: convert C: /fs:ntfs .
slagad is offline
