Old 29-08-2006, 11:44 AM   #1 (permalink)
digiFriend's Avatar
Smile which home inverter to buy
i want to buy 800 va (500 watts) home inverter. select 2 company luminous or APC power inverter.
if you are using any inverter,post your experience about it.
any knowledge/suggestion about inverters/battery are most welcome.
2)what is tubular battery
you never know what you can do until you try
digiFriend is offline
Old 29-08-2006, 07:17 PM   #2 (permalink)
Default Re: which home inverter to buy
I am using Microtek 810 for the last 8 month
and feeling satisfy with it.
no problem
sanju is offline
Old 30-08-2006, 12:36 AM   #3 (permalink)
hmmmmmmmmmmmmm's Avatar
wht is the difference between inverter n UPS ...explain...
hmmmmmmmmmmmmm is offline
