Old 29-08-2006, 09:55 AM   #1 (permalink)
Default DVD to VCD
I have copied DVD(.VOB files) on my computer.i want to convert them to VCD's.Please tell me how can i do this...!
vineetrocks2005 is offline
Old 01-09-2006, 06:00 PM   #2 (permalink)
Mad and Furious
redhat's Avatar
Wink Re: DVD to VCD
I use Nero 6.3 to do the work for me. Nero recode will copy DVD movies to VCD's.
redhat is offline
Old 01-09-2006, 11:17 PM   #3 (permalink)
Pragadheesh's Avatar
Post Re: DVD to VCD
try Xilisoft video converter. its really good.
http://www.xilisoft-video-converter....r/download.php
Pragadheesh is offline
Old 02-09-2006, 01:46 PM   #4 (permalink)
hanwant's Avatar
Thumbs up Re: DVD to VCD
Check this link
http://www.dvd-converter.net/
hanwant is offline
Old 03-09-2006, 05:07 PM   #5 (permalink)
JGuru's Avatar
Default Re: DVD to VCD
You can use Nero. It will do the job for you. You can also try 'Blaze Media Pro'.
It's also a good one. Get it from here
JGuru is offline
