Re: Bets Gaming wheel Under Rs.1000
yeah, there are Steering Wheel available for 1000buck(no force feedback) & 1200-1500(with force feedback).
but dont expect Quality, DURABILITY, & warranty.
& DONT expect force feedback to be powerful enough to rock the wheel. The life of those motors are not at all comparable to Branded ones.
if you wanna go for it any way go to the place in kolkata, which is called Electronic city....or something like that, its famous for electronic goods.
If you know someone who knows that place well (i.e, who can bargain) then only go there.
Branded wheels start at 3000 & above. you'll get force feedback in the range of 4k & above
About the game pad, there are some Chinese make available in the market, which'll cost you 500-600 bucks. they are somewhat durable, i'm using one myself (bought it in chennai) for nearly 8 months now & i got no complaints about it. (they are like PS2 controllers).
WARNING Whatever controller you buy branded/local, Steering Wheel or GamePad, just dont get TOOOOOO involved in the game.
The little joystick in the gamepads are very delicate stuffs. if you play hard, then the joysticks will giveaway.
ASUS K53SV SX520D + BF3
