Re: Restarting frequently
basically, it seems explorer. exe is corrupt
Do this first and try.
Disabling the “restart on system failure” feature may permit the exact cause to be isolated: Right-click on My Computer, click Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” uncheck the box in front of “Automatically restart.”
I am not sure if it will work, but hope that the immediate restart will stop. Atleast you will be able to get a look at the error message.
Also try "sfc /scannow" to see if it shows any discrepancies.
Life is too short. Have fun.
