Old 26-08-2006, 08:01 PM   #1 (permalink)
The Blessed one
Arrow Defragging {query}
Hello guys,
I want to know if I need to back-up my drives, or files, or anyother thing before I start defragging.
The total volume of data on my hard disk is less than 35 GB.How much time will it require for the process.I am using
Windows XP professional
Pentium 4;
2.6GHz
256 MB RAM
Any help is appreciated.
Thank You.
fatguysmart is offline
Old 26-08-2006, 08:20 PM   #2 (permalink)
UBERGEEK
PCWORM's Avatar
Default Re: Defragging {query}
hey man...it will take approximately 1.5 hours 4 defragging..
PCWORM is offline
Old 26-08-2006, 08:24 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
Go here & u'll understand about Defragging http://www.answers.com/Defragment
You dont need to BACK-UP any thing. Just make sure the DRIVE you are going to Run Defragmenter has 15% free space.
Before running Defragmenter press "Analyze", to confirm whether the Drive Needs to be Defragmented.
The process may take a 20 minutes or more.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 26-08-2006, 08:26 PM   #4 (permalink)
The Blessed one
Thanks guyz!
Old 26-08-2006, 08:33 PM   #5 (permalink)
Tux Fan
shaunak's Avatar
defragmentation is faster in NTFS than on FAT file systems.
on NTFS you may need any thing from 45 to 70 mins depending on the level of fragmentation.
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 26-08-2006, 09:03 PM   #6 (permalink)
The Blessed one
Yes I realized that it really takes a lot of time.
Only 1% in 10 mins.
But I have more qurey
If I start the defragment utility and stop it after 15 mins when it is yet to be completed,will it affect my PC?
Old 26-08-2006, 09:21 PM   #7 (permalink)
a_g = JPKN
s18000rpm's Avatar
fatguysmart
if I start the defragment utility and stop it after 15 mins when it is yet to be completed,will it affect my PC?
NOPE.
Some say its a good thing to do, if the process is taking very long to complete. it saves your hard disk from OVERHEATING.
If its taking long (as in your case) Pause/Stop the process for some time & then resume/start. both Pause/Stop are all most same in MS Defragmenter.
Download "Power Defragmenter", it really speeds up the process.
Go here List Of Useful Utilities. u'll find it here
Old 26-08-2006, 11:03 PM   #8 (permalink)
The Blessed one
Originally Posted by s18000rpm
fatguysmart
NOPE.
Very nice software !I will try an d tell you what happens.
And as you said about Overheating,wud that corrupt my data?
Old 27-08-2006, 11:06 AM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
It doesn't corrupts the data but MAY Degrade the performance & life of HD.
See HD is a Mechanical system, so the more it overheats, (like if you run it A 58-60 degree celcius for longer period of time, the HD performance is reduced.
Use the HDD Themometer to monitor ur HD Temperature. its really good as it takes the least system resources.(about 800KB)
You'll find the HDD Thermometer here http://www.rsdsoft.com/downloads.php4
Old 27-08-2006, 08:45 PM   #10 (permalink)
The Blessed one
Thank You guys,I defraged my C drive successfully and the performance has really improved!
