Old 08-12-2004, 08:25 PM   #1 (permalink)
Default HELP NEEDED URGENT!!!!!!
see,i installed alcohol 120% and made a few image files with it.(format:-mdf and mds ).now,i want to burn that image files.nero refuses to recognise those formats. alcohol refuses to be installed again(it was trial) . is there any other program which can burn these image files???????
one more thing,my system when it reeboots gives this error message:- something about system.ini having some files associated with it which are now no more.
please help me.........................
pleaseeeeeeeeeeeee
(ill let u know the exact error message later.)
USING :-Windows 98
RJ THE GREAT
ranjodh is offline
Old 08-12-2004, 08:51 PM   #2 (permalink)
here's the error message
Cannot find a device file that may be needed to run Windows or a Windows application.
The windows registry or SYSTEM.INI file refers to this device file but the device file no longer exists.
If you deleted this file on prpose ,try uninstalling the associated application using its uninstall or setup program.
If you still want to use the application associated with this device file,try reinstalling that application to replace the missing file.
vnesetup.vxd
Press a key to continue.
The same repeats with
vredir.vxd and
dfs.vxd .
then on pressing a key,windows loads and a window with this message appears:-
Unable to load the dynamic link library:
msn32.dll
The system cannot find the file specified.Some or all of the following feature is not available:
Microsoft Networking
Ok button is there.
when u press it,all is fine after that.
I USE WIN 98SE .
Last thing i did was pening nero(although nothing was done), and
tried USB streaming (installed its drivers and tried to burn vcd but it failed) with a sony handycam .
BUT I CERTAINLY DIN'T DELETE ANY FILE.
PLEASE HELP ME................................PLEASEEEEEEEEEEE EEEE
RJ THE GREAT
ranjodh is offline
Old 08-12-2004, 09:08 PM   #3 (permalink)
keep ur 98 cd ready
- go to safe mode of 98
- in add/rem prog , go to windows setup tab . uncheck all the options in communication , online services and click ok .
- reboot into normal 98
- go back to add/rem prog , go to windows setup tab . check all the options in communication u need , mainly dial up networking .
- restart and see if u get the error
else
- run sfc from start menu and specify the file to be extracted from original cd
if above solves some errors
- try reintalling nero and that alchohol thing just to get back those files in the error
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
Old 08-12-2004, 10:21 PM   #4 (permalink)
munim
Posts: n/a
are these 2 problems related? i mean did that windows problem occur after that alchohol thingy trial expired?
try using the repair feature in windows CD... i am not sure if its there is 98se.. its there in xp.
Old 08-12-2004, 10:32 PM   #5 (permalink)
2 might not even be related and no not exactly koz it expired . but some files might have been badly overwrittn , corrupted etc and just deleted instead of uninstal or reg problems . so he can try restoring those files and making a clean install and uninstall to mend things .
klinux is offline
Old 09-12-2004, 12:56 AM   #6 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm... .Mds files are recognised by IsoBuster .. Just open the file in Iso buster and extract the contents and then burn the cd .. Btw .. there are many Virtual Drive emulator around that will recognise MDS files.. And I remember .MD5 files can be loaded in Nero Imagdrive too .. Try it ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 11-12-2004, 07:50 PM   #7 (permalink)
no,the probs aren't related.i have decided to install win xp but again there has been some problem .i am still trying.anyways,the windows thing happened bfore the alcohol one.
RJ THE GREAT
ranjodh is offline
