08-12-2004, 04:27 PM
RESTARTING PC
MY FRIEND HAS A 4 YR OLD PC
CONFIG:
P III 1.1 gHZ
256 SDRAM
HIS MAXTONE MOBO
HIS PC KEEPS ON RESTARTING
HE HAS CHECKED FOR VIRUSES, BUT TO NO AVAIL
HIS PC STARTS NORMALLY BUT RESTARTS AUTOMATICALLY AFTER 5-10 MINS
HE IS USING WIN98SE
HELP NEEDED URGENTLY
Education... has produced a vast population able to read but unable to distinguish what is worth reading
08-12-2004, 04:44 PM
Mostly its not a virus. Its probably got to do with your H/W component such as RAM or CPU or mobo or Graphics Card. read the thread posted by me with the subject PC issues. I had the same sort of problems that whenever I clicked WMP or games it just restarts.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
09-12-2004, 02:09 AM
Hanging, since 2004..
same thing happened to my pc. the most possible prob is that the grip of ram on the mobo is not firm so fix it prperly . the other case may be that ur ram is faulty. get it changed if the prob presists.
Windows 8 ? :lol:
I have a better OS installed, people call it Windows7 8-)
09-12-2004, 02:00 PM
hello,, open ur system cabinet ,,, and make it clean with any suitable brush.. and press the each component very carefuly on ur motherboard .............
don't forget 2 check the POWER SUPPLY Unit of ur system ( like UPS , SMPS etc. )
जय माता दी
It\'s Ok.... u r the best ,,,, i can speak more lie ,if u r happy with it,,, WWW.GOOGLE.COM is BIG BOSS !!!
09-12-2004, 02:20 PM
SymbianGeek
Get the system's SMPS checked probably that the culprit.
Bye.
--eminemence.
09-12-2004, 02:29 PM
SMPS !! remove the SPMS with a new one!!!
Do check ur M/B battery once too.... gud luck ..
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
14-12-2004, 03:16 PM
thanks
changed the cmos battery
works fine now
thanks forthe help
14-12-2004, 06:28 PM
perhaps the smps .try changing it
14-12-2004, 11:34 PM
Technoholik !!
Well if u hear a long beap during startup this is mostly the ram problem reseat it on the mobo, check urs other devices connected to the mobo, like for example the modem , etc, they may not be seated properly. If this doesn't works, remove the CMOS battery and replace it after a sort delay. good luck
[Desktop]
[CPU] Intel C2D 2.4Ghz || [RAM] 2GB DDR2 || [VDU] Samsung P2370MS 23”|| [HDD] 500GB Seagate 7200RPM SATA || [OS] Mac OS X (Hackintosh)
[Laptop]
14-12-2004, 11:38 PM
Technoholik !!
If u run an antivirus program that does not mean it will detect all the viruses, this problem could also be due to a virus which has not been detected. Go the microsoft site and download all possible patchs this could resolve ur problem.
[Desktop]
[Laptop]
14-12-2004, 11:49 PM
what the hell is wrong with u ppl cant u read ?
works fine now
thanks forthe help
No Mercy, No Limits.
15-12-2004, 10:57 AM
First tell me have u done these steps ... and don't forget to check  Power Option in Control Panal
जय माता दी
Search this Thread |
