Old 23-08-2006, 05:33 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default XVID to DVD Format???
Hi Guys!
I have a few videos in XVID format which I want to convert in DVD format so that I can watch them in my DVD Player which doesn't support XVID format. Can anyone tell me which is the best software to convert XVID to DVD without much quality loss and automatic size analysis.
At present I am using ConvertXtoDVD from VSO and the output quality it gives is pretty good. Moreover it automatically does the bitrate calculations. By automatic calculations I mean that if I put just one movie in a DVD, it used the whole disk space for the movie and on the other hand if I put 4 movies, it automatically calculates the bitrate to fir all the movies in One DVD, still preserving the best quality. The only drawback of this software is that it is very very slow. It encodes the movie at just 2X speed. So if I put three movies, each of 2 hrs long, it takes about 3 hrs. to make the DVD.
Thank you.
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 24-08-2006, 09:38 PM   #2 (permalink)
nil_3's Avatar
Default Re: XVID to DVD Format???
You can safely use Ulead VideoStudio. It can analyse the optimum bit-rate by considering the Disc-size, and the DVD would be menu-enabled. But be prepared to face some amount of quality loss.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 25-08-2006, 09:13 PM   #3 (permalink)
TmpgEnc Express. But it costs money.
-Keith
Keith Sebastian is offline
