Old 22-08-2006, 04:41 PM   #1 (permalink)
JBP
JBP's Avatar
Default Home Theater suggestion
Hi Guys,
I would like to plan a home theater system with a budget of 10-16K. I have DVD player. Can u suggest which one is better in the current models. Wht abt Philips HTR5000?
JBP is offline
Old 22-08-2006, 07:14 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
Default Re: Home Theater suggestion
i would advice the new SONY; some 15K. just bought it. awesome clarity
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 23-08-2006, 11:42 AM   #3 (permalink)
Go for ONKYO, It's excellent. And not so costly like Bose and others. SOny and Phillips are not comparable to that.
shiva.kb is offline
Old 23-08-2006, 04:35 PM   #4 (permalink)
don't go for Philips HTR 5000 bcoz audio quality is not up to the mark as compared to sony,samsung etc. check out some samsung models. Sony is best from my point of view bcoz of its price to performance ratio.excellent audio quality
LIVE LIFE KINGSIZE!!!!!!
SHREY is offline
Old 23-08-2006, 05:01 PM   #5 (permalink)
Dhaval's Avatar
I think yamaha and onkyo products are what a proper home theater system should be , you should check out the 6.1 AV reciever (RX series from yamaha)from both yamaha and onkyo with proper speaker package.
You can also have a look at HTiB (home theater in a box) series from yamaha, it takes care of all the setup hassles associated with configuring a home theater system.
Cheers
DhavaL
AMD Athlon 3000+, Asus A8n MB, 1 GB , nVidia GeForce 7300 GT ....
Dhaval is offline
Old 24-08-2006, 01:06 PM   #6 (permalink)
JBP
JBP's Avatar
Thx for ur suggestion... In Onkyoindia website only two Home theater models (HT-S590 & HT-S580) are available. Remaining all are HTib. Is it performs good. Do u've any idea abt the cost of Onkyo models?
JBP is offline
Old 24-08-2006, 02:22 PM   #7 (permalink)
Dhaval's Avatar
Well i live in nagpur, which is a small city, nagpur does have a yamaha dealer but no onkyo one. So i can't exactly tell you about it. But onkyo and yamaha both are quite good.
What i can tell you is that yamaha's rx 350 HTiB system retails for about 20,000 ( i am not exactly sure, but its worth the money). If you want i can enquire about the exact cost.
Cheers
DhavaL
Dhaval is offline
Old 28-09-2006, 10:55 AM   #8 (permalink)
Can u enquire with the yamaha dealer in Nagpur and get the address of the bangalore dealer?
Thanx a lot.
ha_shock is offline
Old 28-09-2006, 11:07 AM   #9 (permalink)
JBP
JBP's Avatar
Plz enquire chennai dealer address too...
JBP is offline
Old 28-09-2006, 03:32 PM   #10 (permalink)
I noticed that the Home Theater in a Box package from Sony costs less than buying receivers and speakers separately. Is this generally the case and if so, why?
Arun
sakumar79 is offline
Old 07-10-2006, 04:41 AM   #11 (permalink)
Mr. S Nova
supernova's Avatar
Yes it is a usual case due to marketing strategy of the companies
i.e. if you buy all the items of the same brand, they offer you a better priced package.
It's also due to economies of scale.. but more of a marketing gimmick only
Knock Knock. Who's there? Opportunity. Can't be, opportunity knocks only once...
supernova is offline
