Old 22-08-2006, 09:32 AM   #1 (permalink)
executioner's Avatar
Question Mounting DVD image
Hi,
can i mount a dvd image even if i don't have a DVD drive using daemon tools?
executioner is offline
Old 22-08-2006, 09:55 AM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Mounting DVD image
Originally Posted by executioner
Hi,
Yeah,you can mount dvd image via powerISO or daemon tool or alcohol120 %.
do you have legal dvd image ?
Third Eye is offline
Old 22-08-2006, 10:05 AM   #3 (permalink)
Yes you can. It's exactly the same procedure as mounting a CD image.
drvarunmehta is offline
Old 22-08-2006, 10:49 AM   #4 (permalink)
make sure u r having NTFS partition otherwise u wont be able to create or copy DVD image in ur hard disk
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 22-08-2006, 11:02 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
Sure you can cause tools like Daemon create a virtual drive and dont depend on the physical ones to function.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 22-08-2006, 12:20 PM   #6 (permalink)
gooby pls
Third Eye's Avatar
FAT 32 File System doesnot support 4GB Single data.
NTFS can !
Old 22-08-2006, 12:33 PM   #7 (permalink)
My dvd image is split into many parts so that i can write it into cd's.can that be mounted using daemon tools even if i don't have a dvd drive as a single dvd.i split the image while creating it using alcohol and i will write it on cd's and give it to a friend who dosen't have dvd drive.will that work for him.
Old 22-08-2006, 01:14 PM   #8 (permalink)
Beware of the innocent
ilugd's Avatar
that is the idea of providing split disc functionality in alcohol, isn't it?
Life is too short. Have fun.
ilugd is offline
