View Poll Results: Is Zone Alarm the best Firewall
Yes 7 36.84%
No 12 63.16%
Voters: 19. You may not vote on this poll
Old 07-12-2004, 07:29 PM   #1 (permalink)
Default Hacking attempts
I have Win 98se as my OS. The moment I connect to the net Zone alarm system suite detects port scan attempts and blocks it. Is there any way that this can be stopped. Someone tries to connect to port 139 or to port 1434. Is there anyway to stop all this.
Shikhar is offline
Old 07-12-2004, 08:39 PM   #2 (permalink)
FooBar Guy
GNUrag's Avatar
Default Re: Hacking attempts
There is nothing called as Best Firewall.... Firewall's rules have to be good enough. And that means it all depends upon who is configuring firewall rules...
Zone Alarm comes with good default rules that make it popular....
http://web.gnuer.org
GNUrag is offline
Old 07-12-2004, 08:56 PM   #3 (permalink)
gxsaurav
Posts: n/a
there is only 1 best firewwall I have seen, the hardware firewalls, they are hard to beat
don't worry about port scan. Zone Alarm will block it by default, I use sygate, well it deos it for me
The best is Windows XP SP2 inbuilt firewall, all ports are closed by default, only when required a port is opened & only that data gets inside which was called by your PC, so no one else can send data in your PC with it, however, since it is integrated in Windows so it is dependent on other windows component, in which if there is a flaw then it can be breached
Old 07-12-2004, 08:56 PM   #4 (permalink)
Bewitched!
xenkatesh's Avatar
I agree with GNurag but.. my choice is Zone alarm
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 07-12-2004, 10:47 PM   #5 (permalink)
If ur net connection is cable or broadband
I mean an always on connection then your system is at huge risk.
Zone alarm is quite good.
But win98 is very venerable on networks.
Upgrade to xp or atlease win2000
The Internet connection firewall you get in sp2 for winxp is quite good.
You can also try norton internet security.
Its has a lot of features including a firewall.
But anyway u will have to configure your firewall
The default settings in zone alarm are good enough.
amitsaudy is offline
Old 07-12-2004, 11:47 PM   #6 (permalink)
Technoholik !!
Tech&ME's Avatar
What r u doing with Win98, first upgrade your PC to Win XP or 2000, then talk about firewalls. Win98 is not quite good for internet use, even if u have an original and updated win98 on your PC. Win XP or 2000 has been build very differently from its previous OS's. Try Norton Internet Firewall as an alternative its quite good.
[Desktop]
[Laptop]
Tech&ME is offline
Old 08-12-2004, 09:06 PM   #7 (permalink)
My experiences weren't good with Win2000. It hanged too often and Zone Alarm System suite wasn't working well in Win 2000. I installed Win XP on my 2nd partition I upgraded to WIN XPSP2 RPC2 Beta version which was provided on Oct or Nov issue of Digit. This buggy beta version had some problems like I could not connect to the net.
Shikhar is offline
Old 10-12-2004, 12:00 AM   #8 (permalink)
Technoholik !!
Tech&ME's Avatar
Well Shikhar why don't u uninstall Win XP SP2 RC2 Beta and install SP2 Final it is also now included with the Digit CDs. But my advice will be to visit the microsoft website first and understand the pre-requirements before you install SP2 final. To resolve issues after you install SP2, you must follow the instructions given on the website. Remove spyware and other unwanted applications (freewares/sharewares) before installing SP2. I am telling you all this because some guys in this forum had installed SP2 and got into some problems. I have installed SP2 and have no problems. Yes, problems can be there if u do not install it correctly, because it is not an application that u can install as u want. This is mostly a Security Update and makes wide changes to the OS.
[Desktop]
[Laptop]
Tech&ME is offline
Old 10-12-2004, 02:38 AM   #9 (permalink)
Web Entrepreneur
ShekharPalash's Avatar
I'm on plain NAV 2005 Standard without any firewall...
NAV's IWC feature is good...
It detects lot of scans... I'm living fine on the internet with it.
Live Chat with Doctors 24x7 on my site http://healthcaremagic.com
ShekharPalash is offline
Old 10-12-2004, 12:02 PM   #10 (permalink)
King of my own Castle
freshseasons's Avatar
ZoneAlarm Pro version:5.5.062.000 and after are the best i think. Zone alarm has ironed out lots of issues it had and i think in the present form its the best.
However the most important point is how you configure a firewall . The permissions you give your firewall is the sole thing that will make it best or worse. So to pick up the best firewall one needs to check how its configured at the default settings.
ZoneAlarm hits the sweet spot for me.
freshseasons is offline
Old 10-12-2004, 04:42 PM   #11 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. I am running Kaspersky Anti Hacker trial these days ..Looks a good software to me .. And its the only other Firewall with stealth feature that I know of .. It uses very small resources and thats why I am liking it ... Will keep you updated ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 10-12-2004, 05:30 PM   #12 (permalink)
mariner's Avatar
i m on lan and very happy with the performance of sygate !!!!!!!!!!!!!!!!!!
mariner is offline
Old 20-12-2004, 01:56 PM   #13 (permalink)
Had Sygate on my PC. Even after setting up the rules couldn't stop even one attempt. maybe because it was old version. Tried Outpost Firewall as well but it blocked my net access only . Someone tries to hack my PC every 1 minute. Is anyone of you suffering from the same problem???
Shikhar is offline
Old 20-12-2004, 03:33 PM   #14 (permalink)
I posted this earlier :
http://www.firewallleaktester.com/tests.htm
and I have been using Look n Stop and its very very good. Very small foot print and highly configurable. You guys def have to check it out.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 21-12-2004, 04:10 PM   #15 (permalink)
HAF 922 Owner
i_am_crack's Avatar
Nive question but you should have added an other option like I don't know / I prefer not to say / Firewall????? Whatz it?????
Basically the requirement of firewall depends system to system.... and its performance....and even some times OS.. (for your info XP hase inbuilt) Where as Zone alaram is also good Sygate people prefer... but it should not slowup the performance of system / internet.....and the last thing i hate is loading in startup and delaying the process startup... Hope you understand what i mean to
Well Actually I forgot to say Hi to you???? Can I say now???
i_am_crack is offline
Old 21-12-2004, 06:53 PM   #16 (permalink)
outpost for me.....
grinning_devil is offline
Old 21-12-2004, 10:43 PM   #17 (permalink)
he was actually lookin for info
so i dun think those options apply
they just INVITE spam which is frowned upon
check icecoolz link .. ull know what sp2s firewall is like
hmm i havent seen a sygate user
most of the ppl i know use zone alarm
boss everyone knows what ur talkin abt
thats y MOST of us shifted from [outoftopic] Norton Antivirus [/endofoutoftopic]
No Mercy, No Limits.
theraven is offline
