Old 21-08-2006, 08:23 AM   #1 (permalink)
True Techie
nithinks's Avatar
Question Removing Visited site names in IE
hello members,
I want to remove all the website names that i recently visited in IE..
how can i do that..?
i tried removing entire history also all cookies.. but its of no use..
when i type a part of the site names.. entire sitename will appear.. below the
address bar..
Can anyone solve this..?
http://www.mytechyard.com/
nithinks is offline
Old 21-08-2006, 09:15 AM   #2 (permalink)
Anand_RF's Avatar
Default Re: Removing Visited site names in IE
Goto Internet Options, Content Tab, Autocomplete. Then turn off auto-complete for Web addresses.
Anand_RF is offline
Old 21-08-2006, 09:19 AM   #3 (permalink)
True Techie
nithinks's Avatar
thats Ok.. but if we go to dropdown.. names will be there...
nithinks is offline
Old 21-08-2006, 09:23 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
Did you clear the history properly? I mean it should all be erased when you do that. Try doing that again and see ?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-08-2006, 09:24 AM   #5 (permalink)
Come get Some
DukeNukem's Avatar
Bro.
install History cleaner or soft. like that
DukeNukem is offline
Old 21-08-2006, 10:18 AM   #6 (permalink)
yaar u dont have to install any software to clean ur history
QwertyManiac is right, u shud clear ur history properly ,it must solve ur problem.
BTW y do u wanna do that
signature??? :???: Let Me Think About It!!!:-D
paul_007 is offline
Old 21-08-2006, 12:46 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
In regedit, goto:
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\TypedURLs
And in right-side pane, u can delete the URLs u want
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 21-08-2006, 01:18 PM   #8 (permalink)
JGuru's Avatar
@Nithinks, There is an option called 'Clear History' in IE. That will do the job for you.
JGuru is offline
Old 21-08-2006, 02:38 PM   #9 (permalink)
Anand_RF's Avatar
Yes clear history will be enough. Also set the "Number of days to keep pages in History" to 1, just in case you forget to clear everyday.
Also, IE is not exactly the best browser to use to visit "sites."
Anand_RF is offline
Old 24-08-2006, 12:43 PM   #10 (permalink)
Download and use CCleaner software. It does a wonderful job
racha is offline
Old 24-08-2006, 01:07 PM   #11 (permalink)
mera kutch nahi ho sakta
chesss's Avatar
Just use Opera. You can remove all history/private settings with one click.
and then forget all hostory-cleaneres/cclean.
and to visit certain 'sites', try Opera portable - This will automatically wipe every setting, when you close the browser, so not trace of your surfing will be left behind.
chesss is offline
Old 24-08-2006, 01:36 PM   #12 (permalink)
Distinguished Member
anandk's Avatar
visit www.ccleaner.com and download ccleaner.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 26-08-2006, 02:16 AM   #13 (permalink)
Desperado's Avatar
Smile Re: Removing Visited site names in IE
i uninstalled NOrton..but i realy liked one of its feature..the cleaner which wud free out space on drives... can u guys recommend any software dat does the same.. is ccleaner my choice?????
Friendly Neighbourhood,
Shahid
Desperado is offline
Old 26-08-2006, 12:28 PM   #14 (permalink)
anandk's Avatar
ccleaner is freeware and fast and effective.
others i rate high are ace utilities, tune-up, system mechanic, anti-tracks.
Microsoft® MVP
anandk is offline
