Old 21-08-2006, 01:22 AM   #1 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
Unhappy friends i want ur inovative ideas
friends..
just now as our exams are over so we friends are planning to make some software which will be really inovative and can be used for some competations like software development comp using VB, .net, c etc..
am really confused wat to mak.. i want ideas from u people..
help!
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 21-08-2006, 01:31 PM   #2 (permalink)
kl_ravi's Avatar
Default Re: friends i want ur inovative ideas
try to build a form using VB and store the data entered in the form in a database. Which is your native language ???
You may try Regional Language <= => English Dictionary.
For hints checkout http://www.kannadakasturi.com It is a Kannada > English > Kannada Dictionary using VB & MS Access with baraha fonts...
Goodluck to you.
Everything that follows is a result of what you see here...!!!
kl_ravi is offline
Old 21-08-2006, 04:25 PM   #3 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
try making a software that would identify all pnp device connected on your computer without the need of drivers for older versions of windows(means if a decive is pnp for XP then it is not necessary that it will be pnp for win 98 right....)...
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 22-08-2006, 01:05 AM   #4 (permalink)
thnx any more!
Old 22-08-2006, 01:51 PM   #5 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
make something unique..
My suggestion:
Just like there is history thingy in all programs liek browser,windows,players. Make a histroy recorder that trackes histroy of multiple people over ur LAN and the internet via a small cient side app. It should store the info in a central location to statistically record a groups' habit of computer usage. This can be unique and usefull.
PS: dont save the IP or the username or it might get called invasion of privecy.
this is cool i think.
I am a guy with odd out of the box ideas. if anyone wants more buzz me.
Rollercoaster is offline
Old 22-08-2006, 03:17 PM   #6 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Try to make a plugin for Orkut that would find all the scraps in your scrap book from one particluar person.
P.S. If this one already exists, please tell me about it.
ctrl_alt_del is offline
Old 24-08-2006, 02:53 PM   #7 (permalink)
The Researcher
Try to make a software that will talk in the indian languges, like Hindi, Marathi, Gujarthi, etc.
Ramakrishnan is offline
Old 24-08-2006, 04:40 PM   #8 (permalink)
jz2linkinpark's Avatar
try make software which imitates super scientific calcualtors,which can do thousands of types of problems in a flash,that would be really helpful.
also try making browser faster than firefox......
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
jz2linkinpark is offline
Old 24-08-2006, 06:16 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
Try to make software Which will detect whether the copy of Games, Softwares & O.S, are original or not.
If they are not Original (i.e. Pirated/Cracked), then your software should completely disable that Pirated Software & put some hidden Info into the Registry or the OS, so the future re-install of that same Pirated Software should also be Disabled.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 24-08-2006, 06:40 PM   #10 (permalink)
Google Bot
Pathik's Avatar
cant be.... wen even ms n ubisoft n big companies cant .... how can he????
Pathik is offline
Old 24-08-2006, 06:49 PM   #11 (permalink)
Commander in Chief
QwertyManiac's Avatar
Spywares are against the law too
Harsh J
www.harshj.com
QwertyManiac is offline
Old 24-08-2006, 09:21 PM   #12 (permalink)
nil_3's Avatar
My suggestion is to create a software which when given a sample voice, will determine and store the voice's pitch, modulation, frequency and other parameters. Now, whenever a song is fed, it will emulate that voice. In this way, after the death of some popular singer, we can get new songs in that singers emulated voice.
BTW is there any such software available?
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 24-08-2006, 10:35 PM   #13 (permalink)
you all giving Hifi ideas.... i want to tell you a low-fi one.... it wont really help you in any competition...
make a program that will beep or make some sound (preferrably with pc speaker... bcause the speakers might be off) after you have finished copying that movie that was taking so long to copy....
it might sound stupid to you, but its useful when the copying is goiing on in the background...
also... can we have a program showing us a more reliable estimate of the 'remaining time'?
A man needs a certain amount of madness to cut the rope and set him free...
mvishnu is offline
Old 24-08-2006, 10:53 PM   #14 (permalink)
String Phreak
mediator's Avatar
@kaushik....................I make some network tool program like portscanner or bruteforce cracker....What say??
mediator is offline
Old 25-08-2006, 06:37 PM   #15 (permalink)
Beware of the innocent
ilugd's Avatar
I was trying to do a project but stopped doing it due to lack of time. Basically, it is something like this.
the software will run in a kiosk at a car showroom. the customer can select a model, and a color
the system will load the photo for that. The customer can then look at different views and colors of the car and make his choice. The service reps should be easily able to remove and add cars and images.
(Just for a challenge, no access or xml databases, ok?)
Life is too short. Have fun.
ilugd is offline
Old 25-08-2006, 09:37 PM   #16 (permalink)
choudang's Avatar
IN VB.... try to make a program which will convert the linux command to DOS... like if i type ls -l it will work as a dir
For every action, there is an equal and opposite criticism.
choudang is offline
Old 26-08-2006, 04:33 AM   #17 (permalink)
knight17's Avatar
Not in India.
"It's not a silly question if you can't answer it." Sophie's World [ http://en.wikipedia.org/wiki/Sophie's_World ]
knight17 is offline
Old 26-08-2006, 07:57 AM   #18 (permalink)
left this forum longback
praka123's Avatar
Post Re: friends i want ur inovative ideas
make a translitrator editor like yudit in Linux.Best of Lux
http://www.yudit.org/
praka123 is offline
Old 26-08-2006, 08:38 PM   #19 (permalink)
dudes those are some huge ideas.. if even a quarter of them are realised correctly then we are looking at a few new bill gates and microsofts here...
Salute...
