Old 20-08-2006, 10:56 PM   #1 (permalink)
Default Pen Drive is shutting down Computer
Recently one of my friend had purchased Transcend Jet Flash pen drive of 1GB capacity. After some time his computer (OS - Windows 2000) has developed a peculiar tenedency. Whenever the pen drive is withdrawn from the computer, the computer restarts. However, the same pen drive is functioning well with other computers and also other pen drives are functioning well with his computer. Please suggest any remedial measure.
Abhijit
abhijitroy is offline
Old 20-08-2006, 11:57 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Pen Driving is shutting down Computer
Do u always stop the service by clicking on the system tray icon before withdrawing the PEN drive?
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 21-08-2006, 01:09 AM   #3 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
i think u should check for virus
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 21-08-2006, 07:46 AM   #4 (permalink)
q3_abhi's Avatar
Hey sometimes the USB ports touch the restart button from the inside.....this too happened with my friend.(if ur using the front USB ports)
If ur connecting to the front ports, check this thing.
Fragging is the key to Success!!!!!
My blog : http://q3abhi.wordpress.com
q3_abhi is offline
Old 21-08-2006, 10:29 AM   #5 (permalink)
Let the music play.....
djmykey's Avatar
He might have installed the drivers which came with the pen drive. It has some functions that u mentioned above. Check if he has done this.
djmykey is offline
Old 21-08-2006, 03:32 PM   #6 (permalink)
champ_rock
champ_rock's Avatar
just tell him dont run the inbuilt program (on the root of the program) which he must be using to access his private partition...
there is a option of restart in transcend software.. just check whether he has enabled that?
Registered Linux user number 400618
champ_rock is offline
Old 21-08-2006, 11:03 PM   #7 (permalink)
Following facts are true with the computer of my friend:
1. It has front USB ports and my friend uses the same;
2. He withdraws the pen drive by disabling it first from the sys tray icon.
Rest whether he has installed the package software or not that I'll check and inform.
Abhijit
