Old 07-12-2004, 11:54 AM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default w2k help files
some of my help files r missing ???
whenever i click on any related link, i get any error saying file not found ...
is it possible 2 install all of the help files again from my w2k cd ???
how can i do that ???
ax3 is offline
Old 07-12-2004, 06:33 PM   #2 (permalink)
i think u can use sfc - system file checker
sfc is used to restore all the lost, missin, corrupted, or "modified" system files.
try it but be sure not to replace those system files which u know u have updated
i dunno wether this wud help coz sfc is used for only recovering system files... but give it a try...
thinkdigit is offline
Old 07-12-2004, 06:57 PM   #3 (permalink)
swatkat's Avatar
Help files can not be installed from SFC.
If u r facing problems with hlp files related to some standard accessories,try reinstalling them with the "Add/Remove Windows Components" from the Add/Remove Programs in Control Panel.
http://swatrant.blogspot.com/
swatkat is offline
Old 09-12-2004, 10:42 AM   #4 (permalink)
ax3
ax3's Avatar
cannot find them to reinstalling in "Add/Remove Windows Components" from the Add/Remove Programs in Control Panel.
nahi mila
ax3 is offline
Old 09-12-2004, 10:49 AM   #5 (permalink)
which screen on which applications window do u actually click on to get the error file not found . try giving a screen shot . is the help missing for any particular application or windows 2000 help files .
If you make yourself more than just a man, if you devote yourself to an ideal... You become something else entirely
klinux is offline
