Old 18-08-2006, 10:45 PM   #1 (permalink)
thetopcyborg's Avatar
Default Who(what) is eating my bandwidth? Detective sware reqd.
hey all,
i recently noticed that when my computer is idle and my internet on, data is sent and recvd continuously...
my first suspicion was automatic updates...i turned it off temporarily, but still the problem continued...
my second suspicion was live update....i let it complete but still the problem persisted...
then i thought that surely it must be a spyware or virus...i ran norton and spybot, removed some spies, but still the problem persisted
now i want to know is that is there any software that will tell me which process and which website is using my bandwidth??? as it is really slowing down my net(As if it wasn't slow already-dial-up )
pls help......i repeat:
a software to tell me what is using my bandwidth(process and website inclusive)
thetopcyborg is offline
Old 18-08-2006, 10:56 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: Who(what) is eating my bandwidth? Detective sware reqd.
listen my advice..swithc off the adsl after every internet use
Third Eye is offline
Old 18-08-2006, 11:21 PM   #3 (permalink)
Commander in Chief
QwertyManiac's Avatar
A firewall does what you want. Install Zone Alarm
Harsh J
www.harshj.com
QwertyManiac is offline
Old 19-08-2006, 12:06 AM   #4 (permalink)
The Blessed one
Arrow Re: Who(what) is eating my bandwidth? Detective sware reqd.
What is the amount of data sent? Is that large ?
And are you on LAN?
IF you are on LAN and data transferred is too little,then relax because this happens with everyone.Your LAN card sends packets to the LAN gateway and inturn receives a reply packet.
Use Active Ports(FREEWARE) to see if any application is using to communicate with the Internet!
fatguysmart is offline
Old 19-08-2006, 04:23 AM   #5 (permalink)
__Virus__'s Avatar
how about a simple netstat -n command and trace the ips?? and as QM pointed out, FW is best way.
Some million years ago, the gods put down there feet, So firmly in to the ground that no man of sword nor pen, could ever chains the rules upon which The very fundament of metal was made.
__Virus__ is offline
Old 19-08-2006, 04:15 PM   #6 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
well your adsl router has ben hacked , shange your router password as well as your internet connection password from the ISP site . if you can't then contact your ISP n get it changed .
coz believe me i myself have hacked more than 100 routers and it just takes 1 MINUTE to hack one.
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 19-08-2006, 07:09 PM   #7 (permalink)
sorry not to make it clear to you that i am currently using dial-up, so each kbps is precious to me....
the size of the data being recvd is about 2-3kbs.....
my major concern is to remove this problem as i am getting an adsl connnection on monday which i plan to run 24hrs.....i dont want my data-limit(1GB) to be wasted....
i dont want to get into the hassles of firewalls.....the active ports dwnld failed at 83%....
pls pls pls help................ :'( :'( as im unable to browse the internet at acceptable speeds
Old 19-08-2006, 07:58 PM   #8 (permalink)
C# Be Sharp !
well you should forward ports that u use n block all others
that's simple
Old 20-08-2006, 12:36 AM   #9 (permalink)
how will i know which ports am i using??????/
i dont know through which port does my browser connect....i hv many messengers....and also, CURRENTLY, i am using my dial-up....there is no port-forwarding in it
Old 20-08-2006, 12:43 AM   #10 (permalink)
JGuru's Avatar
The port the browser uses is '80'. Use ZoneAlarm firewall (www.zonelabs.com),
whether you are using a dial-up or broadband. It will help solve your problem.
JGuru is offline
