Old 07-12-2004, 01:17 AM   #1 (permalink)
The King...
kau_therock's Avatar
Default Urgent help needed
hi guys. i m in trouble.
i am going to buy a graphics card and i dont know which one to buy.
i have short listed fx5600 with 128 mb ddr and fx 5200 with 256 mb ddr.
could u help plz.
also another weird question
could anyone tell me plz what does " EYE CANDY" mean????
Whenever I hear someone pronounce a judgment upon life in general, such as ?Life is unfair,? or ?Life is exciting,? I always think, ?Compared to what??
kau_therock is offline
Old 07-12-2004, 10:39 AM   #2 (permalink)
CHECK UR PM...
delhibhai1000 is offline
Old 07-12-2004, 11:09 AM   #3 (permalink)
go for the fx5600. Dont be fooled by the 256 MB. The fx5200 doesnt even take advantage of it. And also the fx5200 is a old card. DX7 based I think. So if its those 2 then go for the fx5600. Also have a look at the Raedon 9600 standard. Its around 6k
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 07-12-2004, 07:10 PM   #4 (permalink)
The King...
hi
the geforce fx5200 isnt dx7 but dx9 compliant
Old 08-12-2004, 04:08 PM   #5 (permalink)
Hey rock!
according to nvidia fx5200 falls in "mainsrtream" category
whereas 5600/5700 etc fall under "performance" category..
its like a diff between maruti 800 nd alto...both r small size segment cars...
nd both will fulfill the task of taking u to destination...
but alto will provide a lil more "performance" as compared to maruti 800
if u wanna experience all the "bells nd whistles" or according to u "eye candy" stuff turned on then go for any card from their performance series.....
grinning_devil is offline
Old 08-12-2004, 07:52 PM   #6 (permalink)
Default Re: Urgent help needed
could u help plz.
Dude , i suggest u go for Radeon 9600. FX series r poor shader performers n truly a crap.
Go for Club 3d 9600 (n pro)-7k
Club 3d 9600 pro- 8.5k
Club 3d 9600xt-9.5k
The prices r in mumbai!!!
wolfvroger is offline
Old 09-12-2004, 07:11 AM   #7 (permalink)
the prices in delhi.....**told to me**
Geforce 5700 - 6500
Geforce 5700 Ultra - 7000
9800 SE - 12500
9600 XT - 12500
Geforce 5900 XT - 17500
Old 09-12-2004, 08:59 AM   #8 (permalink)
go for ---> fx5600 with 128 mb ddr
quad master is offline
Old 09-12-2004, 11:21 AM   #9 (permalink)
liquid_nitrogen88's Avatar
hey pal wats your budget?
in general radeon cards r better for most of the games barrin a few new ones tweaked to run better on geforce.
if your budget allows,go for radeon 9600/pro/xt.
if u r particular about gettin geforce,consider 5600 or anything above it only.dont go for 5200.
liquid_nitrogen88 is offline
Old 09-12-2004, 12:26 PM   #10 (permalink)
or go for 5700 ultra with 256MB...
thats what iam thinking abt going for....
i'll try to get 5700ultra....otherwise second choice will be 9600XT
though they both r almost on par in performance...so why spend
more??
Old 09-12-2004, 01:51 PM   #11 (permalink)
9600PRO gives higher performance than 5700ultra in all the reviews i read
except in those games designed to run better on geforce cards like doom3(but here also the margin is not so high)the qn is r u willin 2 shell out 5k for a 15% performance boost...
Old 09-12-2004, 02:21 PM   #12 (permalink)
The King...
hi
guys thanks for all ur replies.
i bought fx5200 256 mb. i got this card for just Rs.3500. hope its a fair deal. i dont mind playing games at lower resolutions. i just wanna play nfs u2. thats all.
i m going 2 buy a new computer next month. budget is Rs 50000.
could u plz tell me the best performance configuration.
thanks
Old 09-12-2004, 06:16 PM   #13 (permalink)
Laptoping
Sourabh's Avatar
when u r upgrading ur sys next month n have a budgest of 50k then y did u buy such a cheap card
u shld have atleast went in for a 9600PRO or 5700LE which are around 8 and 6.5k repectively
50k thts a huge sum u can make urself a very good rig with it
Sourabh is offline
Old 10-12-2004, 12:47 AM   #14 (permalink)
KHUBBU's Avatar
Geforce 5700 - 6500
9800 SE - 12500
9600 XT - 12500
cud u plz tell the manufacturer of the above cards.
Brand new Day!
KHUBBU is offline
Old 10-12-2004, 01:12 AM   #15 (permalink)
i bought fx5200 256 mb. i got this card for just Rs.3500. hope its a fair deal. i dont mind playing games at lower resolutions. i just wanna play nfs u2. thats all.i m going 2 buy a new computer next month. budget is Rs 50000.
u shock me pal....
i am gettin a system for 50k now,u will get the details at:
http://www.thinkdigit.com/forum/view...er=asc&start=0
Old 10-12-2004, 07:00 AM   #16 (permalink)
[quote="KHUBBU"]
Geforce 5700 nd 5700 ultra r frm "pine"
gforce 5900XT is frm MSI
radeon 9800se nd 9600XT r frm gigabyte
price as checked frm nehru place!
if sum diff is there do lemme know...
moreover iam going to buy a card TODAY!!
enuf of comaprisons!!!!!
Old 11-12-2004, 12:41 AM   #17 (permalink)
KHUBBU's Avatar
plz do post which one did u bought?
Brand new Day!
KHUBBU is offline
Old 11-12-2004, 12:58 AM   #18 (permalink)
The King...
hi
gave away the fx5200 id bought. now looking to purchase a card @7k.
could u plz tell me which is best
Old 11-12-2004, 01:53 AM   #19 (permalink)
its alraedy posted in this thread.
chek the previous replies.
Old 11-12-2004, 04:49 AM   #20 (permalink)
the 5xxx series is now obsolete. Go for a card in the 6xxx series. Eg GeForce 6600 etc. If the shops don't have it yet, Go for the Fx5700 or the Fx5900 Xt. Between the two, I recomend the Fx5900XT.
Or, You could go for the Ati x300 or x700 cards.
sidman is offline
Old 11-12-2004, 09:23 AM   #21 (permalink)
hey nitrogen...i purchased 6600!!!!
well have to purchase motherboard nd processor to go with it!!
thinking of p4 3ghz with 915 chipset...
ny choices in m'boards???
