Old 17-08-2006, 05:00 PM   #1 (permalink)
vikasg03's Avatar
Default DVD Convert Very slowly to MPEG
hy
i have try many s/w to convert DVD 2 VCD but all are taking too much time to convert DVD (vob file) into VCD(mpeg file). It will take 1 hr to convert 1 hr DVD in general. Is there any software available which can convert fast. Also how to cut DVD, if i want to remove some portion. In VCD we can easily cut with VCD cutter .
I am using win XP , P4-2.4 ,512 MB RAM
thanks
Vikas
Vikas
vikasg03 is offline
Old 17-08-2006, 07:29 PM   #2 (permalink)
Beware of the innocent
ilugd's Avatar
Default Re: DVD Convert Very slowly to MPEG
which software are you using currently?
Life is too short. Have fun.
ilugd is offline
Old 18-08-2006, 12:19 AM   #3 (permalink)
JGuru's Avatar
I don't think you can minimize the time taken for converting DVD to VCD.Since DVD
file are big & take longer time to process.
JGuru is offline
Old 18-08-2006, 06:24 AM   #4 (permalink)
nil_3's Avatar
Originally Posted by vikasg03
...Is there any software available which can convert fast.
Conversion time dapends mainly on processor speed; Your PC configuration is decent enough for video-editing; you may opt for 3-3.2GHz processors but that will make marginal difference in time.
...how to cut DVD, if i want to remove some portion.
Use VideoStudio 10. Here you will find the option to "Insert DVD/DVD-VR" for inserting VIDEO_TS files. Then edit as necessary and convert to MPEG.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 18-08-2006, 09:24 AM   #5 (permalink)
vikasg03's Avatar
hy
GoldLeo DVD Ripper,1 click dvd to vcd,super dvd ripper ...these are the s/ws which i using currently.
vikas
Vikas
vikasg03 is offline
Old 18-08-2006, 04:16 PM   #6 (permalink)
hansraj's Avatar
i used to convert when i didnt own a dvd writer and i too found that if u want a better quality the time only increases and goes upto 8 hours (for 3 hrs of a movie) however this 8 hrs can be reduced to 2 or so by compromising on the quality i.e. dvd x is the best to manipulate this setting in which u can manipulate the settings as per individuals need.
an advice which no one gave me.... if possible buy a dvd writer coz i feel sooner or later u will buy it anyhow and then u wont feel like watching these converted movies.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 18-08-2006, 09:15 PM   #7 (permalink)
hi ...
I suggets u use Ahead DVD Ripper, the current version is (Ahead DVD Ripper 2.3.1) is a gr8 with DVD's . It can covert then in VCD's aswell as in other mp4 formats.
and well i dont think softwares can reduce ur convertion times by much , as it usually depends on other system factors as nil_3 pointed out
raskal is offline
Old 13-09-2006, 11:36 AM   #8 (permalink)
You can't reduce the conversion time. This is a common problem with format conversions in video.
slagad is offline
- by Krow
