Re: SATA HDD Prob!!
Serial ATA is not compatible with IDE (PATA) because the connectors are different,
the voltage levels are different, and SATA sends a bit at a time , while PATA sends
16 bits at once.The two bus interfaces won't be compatible. ie., the IDE bus will not
connect to the SATA bus!! But there are converter boards available, which translate
SATA to PATA interfaces. You can use that for accessing your SATA HD.
