HI,
Currently, I require a TFT monitor., My budget is not more than 11000.
(I am bored of using a CRT). Is there any disadvantage using a TFT(when compared to CRT?)
Please suggest.
Thanks & Regards.
The LCD displays in that budget won't show much difference in fact they have some -ve point as to CRT if you can extend your budget a little i'd suggest you go for the Samsung 940BW it's around 16k and i assure you you won't be disappointed. it's an absolute steal for that price.
