Old 14-08-2006, 10:21 PM   #1 (permalink)
Default remove "shortcut to" from shortcuts
hi,
Without installing Autopatcher, is there any way to remove "shortcut to" prefix from Shortcuts?
Raaza is offline
Old 14-08-2006, 10:41 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: remove "shortcut to" from shortcuts
Start -> RUN and type regedit, nevigate to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer
In right-side pane, create a BINARY value link and set its value to 00 00 00 00
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-08-2006, 11:53 PM   #3 (permalink)
It doesn't work Vishal
Raaza is offline
Old 15-08-2006, 12:07 AM   #4 (permalink)
download tweakui (its a microsoft official app & free)... theres an option for doing what you want... plus it will let you do so much more...
kikass is offline
Old 15-08-2006, 12:11 AM   #5 (permalink)
Microsoft MVP
Try the same trick to:
HKEY_USERS\S-1-5-21-xxxxxx-xxxxxxxx-xxxxxx-xxx\Software\Microsoft\Windows\CurrentVersion\Expl orer
Old 15-08-2006, 12:22 AM   #6 (permalink)
QA Juggler
saROMan's Avatar
get TweakUI from here : www.microsoft.com/windowsxp/ downloads/powertoys/xppowertoys.mspx
you can remove the prefix in seconds with it
OR Trust microsoft
http://support.microsoft.com/?kbid=253212
support.microsoft.com/kb/555535/en-us
OR
www.winguides.com/registry/display.php/339
www.activewin.com/tips/reg/explorer_8.shtml
forum.networktechs.com/archive/topic.php/t-70002.html
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 15-08-2006, 12:41 PM   #7 (permalink)
with Tweakui, I removed shortcut prefix.
thnx 4 the sharing
Raaza is offline
Old 16-08-2006, 06:00 AM   #8 (permalink)
nil_3's Avatar
Use RegSeeker 1.45. It is available at http://www.hoverdesk.net/freeware.htm. It is freeware!
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
- by Krow
- by gohan89
