Old 14-08-2006, 09:38 PM   #1 (permalink)
Mobile Addict
Question Blocked Port Finder
Can anyone of you recommend a program which searches and tells me the ports which have been blocked by my ISP or my firewall. Reply soon.
aritrap is offline
Old 14-08-2006, 10:42 PM   #2 (permalink)
siriusb's Avatar
Default Re: Blocked Port Finder
Try these online tools
http://www.auditmypc.com/freescan/scanoptions.asp
http://www.pcflank.com/scanner1.htm
http://www.dslreports.com/scan
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 15-08-2006, 07:52 PM   #3 (permalink)
The Blessed one
Yes!
there is a utility called port sscan!
It scans all ports on your PC and showa which ones are open n closed.
Now that you know this,plz do not use this to cause trouble to some person!
fatguysmart is offline
- by Krow
- by gohan89
