Old 14-08-2006, 07:10 PM   #1 (permalink)
9437077259
go4saket's Avatar
Default Difference in Compressed Disk Image (DAA) & Normal ISO???
Hello guys!
I had always been using ISO format to make an image of a disk. Recently I came across a file type called DAA, created by PowerISO. It claimed that it can create images in compressed format, thereby taking less space. Now, what actually is the technology behind it. Does this image type is the same as our normal compressed files (ZIP/RAR). If so, I am sure whenever we mount this kind of an image, it will first be extracted somewhere in a temp folder before we can use it, thereby making it a slow process.
Kindly clearify...
Chao...
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
Old 14-08-2006, 11:08 PM   #2 (permalink)
siriusb's Avatar
Default Re: Difference in Compressed Disk Image (DAA) & Normal ISO???
No. DAA don't need decompressing to a temp folder to read any file. But it's a proprietory format of poweriso and can only be mounted on it's own virtual drive. Also, to write to a medium, you have to decompress to an iso file and then write it.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 15-08-2006, 08:58 AM   #3 (permalink)
9437077259
go4saket's Avatar
Arre you sure we have to decompress it before writing it to another medium... Cant we just mount the DAA to a virtual drive and use PowerISO or Nero to directly write it to a medium...
Win 7 Ultimate
go4saket is offline
Old 16-08-2006, 05:56 AM   #4 (permalink)
nil_3's Avatar
Nero don't support .DAA format. May be some other virtual drive creating softwares(like Daemon Tools, Virtuadrive etc) can support but I can not say for certain.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 16-08-2006, 06:22 AM   #5 (permalink)
Commander in Chief
QwertyManiac's Avatar
PowerISO itself supports burning .DAA
Harsh J
www.harshj.com
QwertyManiac is offline
Old 16-08-2006, 09:53 PM   #6 (permalink)
JGuru's Avatar
DAA stands for 'Direct Access Archive'.It's an advanced format for an Image file,
which supports compression, password-protection, & splitting to multiple volumes.
It's a proprietary format. Nero doesn't support DAA Image file format!!
Only PowerISO does!!
JGuru is offline
Old 18-08-2006, 12:07 AM   #7 (permalink)
nishant_nms's Avatar
Deamon tools doesn't supports it. Only PowerISO supports it
nishant_nms is offline
- by gohan89
