Old 14-08-2006, 02:07 PM   #1 (permalink)
Default no scandisk even if in case of power failure
hi guys,
here I'm facing a new problem(?) that my pc doesn't perform scandisk when rebooting after a power failure or after pressing the reboot button.
Hence sometimes pc gets down very slow
where can I find the settings for automatic scandisk in case of sudden power failure?
File system is NTFS for all the partitions.
Raaza is offline
Old 14-08-2006, 02:12 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: no scandisk even if in case of power failure
You can try this:
Open regedit and goto:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager
In right-side pane, change the value of BootExecute to:
autocheck autochk *
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 14-08-2006, 05:59 PM   #3 (permalink)
champ_rock
champ_rock's Avatar
i am also facing the same problem.. in my case, the registry value is already "autocheck autochk *".. still it does not scan automatically... what should i do?
Registered Linux user number 400618
champ_rock is offline
Old 14-08-2006, 06:13 PM   #4 (permalink)
siriusb's Avatar
No need to go to registry. Just go to cmd prompt and type in
chkdsk /F /R /V c:
Say 'y' to check on next boot and you get a chkdsk on next boot.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 14-08-2006, 11:52 PM   #5 (permalink)
Originally Posted by Vishal Gupta
You can try this:
autocheck autochk *
I did so,
But the problem is still there,
is there any other methods?
Raaza is offline
Old 15-08-2006, 12:12 AM   #6 (permalink)
QA Juggler
saROMan's Avatar
"Scandisk doesn't exist in NT based systems. XP uses CHKDSK, and there's no easy way to automate it via a script. If a disk/partition/volume is in use, it will have to be dismounted. For your system drive, this usually means that it has to be done after a reboot. Open a command prompt and type CHKDSK /? for the command line options."
here are some solutions
Inside of Windows you can also go to the Command Promt and type chkdsk or chkdsk/r
OR
without any windows gui restart press F8 select safemode with command prompt. CD c:\ [enter]
C:\chkdsk /r [enter]
the "r" repairs
OR
go into my computer and right click on the drive u want to scandisc....a box will pop up....u want to click the tools tab....click error checking....check the two boxes that are there....and click start....it will tell you that it will run scandisc on the next start up....i cant find another way to do it but to restart the pc and then it will do it for you automatically...hope this helps ya.
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 15-08-2006, 04:41 AM   #7 (permalink)
__Virus__'s Avatar
just a thought/question, does ntfs partitions need scanning? to what I remember I never saw a scan after a crash/manual reboot being executed on Xp/NTfs
Some million years ago, the gods put down there feet, So firmly in to the ground that no man of sword nor pen, could ever chains the rules upon which The very fundament of metal was made.
__Virus__ is offline
Old 15-08-2006, 12:47 PM   #8 (permalink)
siriusb's Avatar
o.0 Is my previous reply not visible to anyone?
@__Virus__
Ntfs can become corrupted just like fat though some times chkdsk don't run. To know if your partition has some corruption, either schedule a chkdsk on next boot or try to run defrag on that partition. Disk Defrag will tell you if the partition needs to be chkdsked or not.
siriusb is offline
Old 15-08-2006, 04:40 PM   #9 (permalink)
Level 96 Headbanger
DeSmOnD dAvId's Avatar
AFAIK, NTFS doesnot require a chkdsk frequently. NTFS maintains a journal of all files, if anything goes wrong, it jumps back the bad file from the journal.
"Words meant to dwell in darkness shall never see the light of day.
Words can be broken, so can bones. Execute the mandate." :twisted:
Steam : DeathMetal
Garena : death_metal27
My Blog : The Pandemonium
(Latest Post : Where does music come from?)
Guitar gear : GB&A (acoustic), ESP LTD-M50 (New :twisted:), Roland MicroCube Amp.
DeSmOnD dAvId is offline
Old 15-08-2006, 06:31 PM   #10 (permalink)
if then ok.
thnx 4 the responses once again.
Raaza is offline
- by gohan89
