HI all,
I got a wierd problem recently when i tried to upgrade my nVidia drivers for GeForce FX 5200. The problem is, the system doesnt boot after i restart when the installation is completed.
What i did was-:
1>Uninstalled nvidia drivers from add/remove programs
2>rebooted with onboard video
3>windows detected the video card but DID NOT INSTALL any drivers for it automatically as it should (any idea why? )
4>installed the new 87.25 drivers and rebooted, (PCI vid), but the progress did not further than the windows bootscreen..after which the screen turned black and the comp. hanged
5>when i turned off/on power, the disk eroor check started but that too couldnt continue and it froze after completing
6>PCI video doesnt work for SafeMode as well.
Can any1 tell what have i done wrong and HOW cAN i GET WIN to install drivers automatically?
THX for HElp
PS: i've tried using driver cleaner pro, desnt help.Also i dont have system restore on. THirdly, i AM REALLY NOT interested in reinstalling win ATM, so plz suggest otherwise
